Reduce file size by changing image size
Trebly
Post by Trebly »
Hello,
I tried to find this information into the forum without success. I believe that it probably exist, but where ?
Even I use photo edit tools, I am a new user of video. I made someones but it is the first time that I meet the following problem :
- I have a movie (.mov) with 640x480 image size and the filesize is 32Mo for 2mn45s.
- To view it into a website page I determine that the best should be 320x240 size with a filesize near 10Mo (to begin quickly and have comonly a fluid flow).
I believe that with the same definition a treatment should reduce the filesize (for images I change pixels definition size of the image - so the image disply size at 100%- and later I compress it) in such case the size of the file is reduced by a 4 factor.
When I create a videofile with Mediastudio video editor from 640x480 with a 320x240 size the image quality goes to 320x240 but the filesize is not reduced. Which parameter to change the image dsiplay size and the filesize ?
I am sure that I missed something.
Thank's for your help
MrA
Post by MrA »
My best luck was either rendering it to a wmv file or converting it to a flash file with a utility called Flash Video Studio found at http://www.flashvideostudio.com/. FVS will make a typical file that you have to about 6 megs or so.
I agree with Mr. Amigo2121, especially about converting it to Flash format. Flash seems to be about the most common format used currently for streaming video over the web.
Gorf
Re: Reduce file size by changing image size
Post by Gorf »
Trebly wrote:...When I create a videofile with Mediastudio video editor from 640x480 with a 320x240 size the image quality goes to 320x240 but the filesize is not reduced. Which parameter to change the image dsiplay size and the filesize ?
I am sure that I missed something...
File size has nothing to do with the frame (image) dimensions.
File size is determined by bitrate and duration only.
A one-minute video at 1mbps is always 7.15 MB irrespective of the framesize, codec etc.
The quality - how good it looks - is mosty determined by bitrate, codec, image dimensions, framerate, colour depth and video content.
