capturing frame rate dilemma
redsky
Nature of the problem : When capturing a video using my dv camera, I noticed that its capturing a frame per second rather than 29.297 frames per second. I know its somethng to do with MRSP because I tried capturing with Windows Movie Maker and the playback speed is correct played.
Properties of your source files (format, file size, where did you get it?
AVI.. any size ...panasonic dv camera
What devices are involved and their mode of connection?
Pentium D 3Ghz 2Gigs of ram...fire wire connection
Project Settings
DV(NTSC 29.97fps Audio 48KHZ)
Output format (file, DVD, VCD, SVCD)
PAL or NTSC
NTSC
Error Codes (if any)
[size=18][/size]
Project Settings
PAL or NTSC
NTSC
[size=18][/size]
heinz-oz
You are not making sense. Are you getting the video in DV-AVI format from your camera via firewire? Apart from selecting DV type 1 or type 2 there are no settings and the video is not "captured" in the true sense of the word but rather transferred as is from the camera to the PC.
As a work around, if we can't find out what's wrong, use MovieMaker to capture and MSP to edit. Simple.
What model of camera are you using?
redsky
capturing dilemma
Hi Heinz,
What Im trying to say is that when I tranfer video from my dv camera via fire wire, My playback of that video is very very fast . The reason for this is that it is capturing the footage at a frame per second as opposed to 29.97fps like it should. I have the project settings for AVI..Is there anything I can do to correct this...It hasnt always done this..It just started today.)...Thanks
heinz-oz
Please try to help us to help you. Have a read of this
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8961
and pay particular attention to this part
Which capture plugin are you using? It apears to me that your capture is done in fast forward mode. Which OS are you using?
. Click on the System symbol which will explain to you how to provide your system details.If you haven't already done so please click here --> so that we can then view your system specifications.
heinz-oz
redsky
capturing dilemma
YES!!!!!!!!!!!!!... I resolved the capturing dilemma I was having.. It wasnt a technical problem..I just kind of narrowed down the possible reasons why...and that reason was I had the setting for capturing on Manual.. I found out when its on that particular setting it only captures video.. I am not sure why that is or why it captures a frame per second with the Manual setting but it does.. I just set the paraameters to Auto(no limit) and it worked like a charm:)) ... Thanks for trying to help...
ps... Just out of curiousity..Do you happen to know why it doesnt capture Audio when its set to Manual capture?.. I just like to gain knowledge:) Thanks
heinz-oz
