BUG VS 11 CRASHES when you select auto detect chapters
buercky
Post by buercky »
have noticed that when you create a DISC and select the AUTO DETECT chapters that VS11 shutsdown.
I have already used that feature without any problem with VS11+ running on Vista Home Premium. To be a bug, a problem has to be replicable.
To test it once again, I have just inserted a DVD compliant mpeg-2 into the burning module (after using Share > Create Disc). I selected Add/Edit chapters, then on the next page which appeared, I selected Auto Add Chapters. I selected 1 minute intervals, and the program auto added the chapters at every minute. I clicked OK and went on to build the menu. All appeared normal in the Preview.
Was there anything particular about the video you used? What were its properties? Or did you insert your project into the burning module? Had you already inserted chapter points during the editing phase?
Svuppe
Post by Svuppe »
I have seen that, along with preview didn't work either. Both problems were solved when I installed the latest DirectX update.
Vincej
Post by Vincej »
where do I find the directX patch - how do I install it - I have the same problem ?
thanks Vince
Svuppe
Post by Svuppe »
buercky
Post by buercky »
does anyone know where i can get the latest for XP with out a websetup version. for some reason it says it cant find the server and i dont have a firwall up. and YES my windows is legal.
i found the REDIST version here so if the WEB version doesnt work
http://www.microsoft.com/downloads/deta ... laylang=en
buercky
Post by buercky »
Svuppe wrote:I have seen that, along with preview didn't work either. Both problems were solved when I installed the latest DirectX update.
Svuppe
YOU did it it fixed mine as well just reinstalled the directx as you said and bingo..... it works
NICE FIX.... :P :lol:
Svuppe
Post by Svuppe »
I've received some good help here over the time, so it is nice to be able to give something back. Glad it worked out for you.
JoReneA
Have same problem but already have latest Direct X for Vista
Post by JoReneA »
I have this same problem but there is no way to update the Direct X in Vista beyond what it already has. I have auto updates checked so should have the latest updates, and the updates for Version 9 at the MS site will not work or install on Vista. I could find no place to download a Direct X 10 at the MS site.
The problem can be replicated and happens every time I try to make a disk...or preview...or add chapters, exactly as the other poster had.
Svuppe
Post by Svuppe »
That's odd. I have just installed Vista a couple of days ago, and I don't have these problems at all.
faqvideo
Thank you for help!
Post by faqvideo »
I have run into the same problem and just have had it solved by downloading and installing DirectX9 to my Windows XP SP2 Home. Now I can add chapters. Thank you for sound advice.
jlin
Post by jlin »
i am experiencing the same problem... program shuts down when i try to add chapters automatically
videostudio 11+ , demo
windows vista home premium.
DLA
Post by DLA »
I had the same problem. I tried to install directx_9c_redist.exe and I would still have the problem. Then trying directx_feb2007_redist.exe solved my problem. I have XP SP2.
jlin
Post by jlin »
anyone has any solution?
or do i look for another editing program...
ive already tried pinnacle studio 11, but that was working so sluggishly, it was impossible.
thanks
Can you at least tell us whether you tried the solution found by others in this thread and that it did not work with the trial version?
