i have installed ulead dvd factory 6 plus and imported (added)video clips .
i can see the video preview fine but i can not hear music i could not work out where is the problem is . please help i searched on internet and could,nt find any solution please help.
ulead dvd movie factory no sound in preview please help
ace123
Your video files are probably in a "funny" format. The Read This First post tells you what we need to know in order to help you. (The various highly compressed formats cause the most trouble... formats like DivX with MP3 audio...)
Please avoid the large font, unless you have a vision problem or something... It's OK (maybe even fun) to use the large fonts & colors occasionally to emphasize something, but it's annoying to see the whole thing like that.... Kind of like you are shouting or something...
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
ace123
thanks for ur reply. i noticed when i import window media file sound is ok but in mod file i cant hear the sound below is media clip properties kindly tell me what to do with this format. thanksetech6355 wrote:Right Click on one of the videos after you have inserted it into the timeline and select "Media Properties". Then post the video & audio properties of the video back to this thread.
Can you recapture your snapshoot again, login to the forum, go to this post and re-edit your post & replace with a larger snapshoot image.
I tried to blow it up and can't read it.
The forum doesn't seem to have a choice of Medium size for the font size, it's either Normal or Large. Depends on the settings in your browser though. But you can change this by using a medium size when making a post. Change the size=18 to size=14.
size=12 is Normal
size=18 is Large.
You can customize the size=xx
This is size=18 size=18
This is size=17 size=17
This is size=16 size=16
This is size=15 size=15
This is size=14 size=14
This is size=13 size=13
This is Normal Normal, size=12
size=12 is Normal
size=18 is Large.
ace123
thank you etech for your advice now i know how to post and i have edited my posts too here is large snapshot of properties of file i hope this wud help. thanksetech6355 wrote:Can you recapture your snapshoot again, login to the forum, go to this post and re-edit your post & replace with a larger snapshoot image.
size=12 is Normal
size=18 is Large.
You should be able to hear sound from MF6+, of course check your WAV port setting on your sound mixer card. I guess if using the trial version of MF6+ it should support Dolby audio, I don't know.
You can hear audio when playing the file using other software players?
If using XP, you must have SP2 installed along with the latest directx update to 9.0C
Don't know about Vista, not using it yet.
