the original file when captured is avi ....please help...I was supposed to have this dvd to the customer a week ago...and I am running out of excuses...
thanks in advance
For single layer disc (DVD5), you can up the video bitrate to ~5500kbps (assuming compressed audio of ~256kbps or lower). If you are including dvd-rom data (personal folder), then you have to adjust the bitrate down to account for the space needed for the personal folder. Motion menus also need more space that still menus, so you would have to adjust again to account for the motion menus...jahmarvin wrote:this dvd is 1:45 MIN loong...I have the bitrate set to 2500 for 2 hour dvd is that correct ?
That bitrate is too low! My favorite online Bitrate Calculator says you can use a bitrate of 5200 kbps if you use Dolby audio.this dvd is 1:45 MIN loong...I have the bitrate set to 2500 for 2 hour dvd is that correct ?
Higher bitrate = higher quality = bigger file size = lower compression = less playing time.
Lower bitrate = lower quality = smaller file size = higher compression = more playing time.
