Many thanks for taking the time to put together the above post. It has really given me a great insight to the basic workings of the entire process so I can better structure further questions.
No offense taken at all about not knowing anything because.. well I don't so it's great to have things spelt out like you've just done
Please bear with me with these next few questions, if you don't want to answer them all then I won't complain 'cos there are a bloody lot here!
Please allow me to answer your questions right here in your post. Might help to clarify things.
heinz-oz wrote:First of all, your TV standard determines the frame size needed for full frame DVD. It's 720 x 480 (NTSC) and 720 x 576 (PAL/SECAM). Every bit of TV/DVD you watch on your 40" LCD/PLASMA in standard definition is of that very same frame size. Even 16:9 widescreen can be the same frame size. If that now confuses you, don't worry, you are not alone.
Right, I'm from the UK and use PAL. From what you've just said here, is it safe to assume the best frame size to work in is 720 X 576 as I can make a DVD in addition to playing it in a media player such as WMP and releasing the video online? That is opposed to the other frame sizes including the default 640 X 480 (<why is this the default by the way?). Also just to make sure I have this right, if I successfully make a video using 720 X 576, I can watch it on any sized TV in my house including a 16:9 widescreen?
Ok, we are likely to create some further confusion here since it is never so clear cut. The best quality for DVD you do get from the full frame size but the DVD standard also allows for smaller frame sizes. I would not worry about that too much at this stage and stick to the full frame size.
You can play a DVD in the WIN MP provided you also have a software DVD player installed (WinDVD, PowerDVD etc.) also which provides the mpeg2 decoder. It is not provided by Microsoft as a standard.
To upload your video to the web you should render a version to a smaller frame size and use a different encoder like wmv, DivX etc. I would stay clear of mpeg4 at this point in time since the new MS OS, VISTA does not support it. DivX encoders are not free but wmv comes with Windows as far as I know. I don't use any of these since I don't publish my creations to the web and, hence, have only limited knowledge of them.
heinz-oz wrote:
AVI is as clear a description of your file format as "Bucket" is for liquids. It doesn't mean anything in itself. What's in it (AVI is a container format) counts. AVI can contain DivX, Xvid, mpeg4... you name it.
Okay, so I now understand AVI is a container format for these other things like DivX, Xvid, mpeg4 which I assume to be codecs. Lets say I'm going to capture some footage (from my cheap capture box) and select AVI as the format in Video Studio. How can I tell which of these codec's the program is using? Are they the same that are installed on my computer outside the program? There don't seem to be any options or stuff to analyse this in Video Studio so I'm assuming this is the case. Could these be the reason I'm having slightly choppy video & out of synch audio, because I don't have the right ones installed? How does MPEG2 compare to AVI?
How does an A4 sheet of paper compare to a bucket? You'll have to learn to clarify what you are talking about when using the term "AVI". Mpeg2 is absolutely essential to create a DVD. AVI can be uncompressed video at over 60 GB per hour right down to very highly compressed video at maybe 800 MB or less per hour. These formats do not "compare". They are horses for courses. The reason for these highly compressed formats is the need to stream them from the web. People on dial up are struggling even with these but on broadband it becomes viable. Trying to stream full frame video in DVD compliant mpeg2 (yes, there are non-compliant mpeg2 files about also) from the web, even with a fast broadband connection is impossible because of the time it would take to transmit the data volume. In DVD compliant mpeg2 a 1 hour video could be over 4 GB in size, the same video, in comparable quality could be around 500MB when compressed to DivX. a lot easier to handle than 4 GB. Just don't try to edit that and make a DVD out it again. The missing 3.5 GB would have to be guessed by your converter program because the data is just not there.
heinz-oz wrote:
When we are talking AVI in the context of digital video, more often than not we refer to DV-AVI. This format, while slightly compressed in the camcorder, is not "captured" in the true sense of the word, it's usually transferred into the PC via fire wire (IEEE 1394) connection. There is no capture settings to worry about except for the audio stream. Most commonly and least problematic is DV type 1 which has the audio stream embedded in the video. DV type 2 has a separate audio stream and some NLE editors require that to function. ULEAD programs are very happy with type 1.
Wicked, I'll keep that in mind if ever I stop spending all my money on beer and buy a proper camera.
That prompts me to ask. What camera do you use?
heinz-oz wrote:Any compression used at capture requires a lot of PC resources unless the capture device has a hardware encoder. These tend to be a bit more expensive than the usually cheap USB adapter boxes, pretending to be capture devices, which require the PC to do the compression in real time. This is a very demanding resource intensive task.
Oh dear, it looks likes I have a cheap usb adapter box. When I first read compression there, I got the image of programs like winzip making a file smaller. I'm guessing this is not exactly the case here. By compression, do you mean converting to AVI using the codec things (and it so happens to compress the video to a certain extent)? Lord help me with my superb use of terminology here.
Compression (video) is a bit more involved than zipping up a file. It could involve using a format that requires the use of an AVI container but is not limited to that. DV-AVI, the native format of MiniDV camcorders is compressed in a lossless fashion which means that it is compressed by discarding redundant image information but to the naked eye this is not aparent. Saving such a clip to DV-AVI format over and over again will, in time, result in a quality loss because every time you apply this compression more data gets discarded.
So if I'm using my crappy usb adapter box and my computer is struggling to process all this info, will this have an effect on the quality of the capture? Could this be why my video is sometimes a bit choppy and out of synch? Could I get away with using my existing box and tweaking settings elsewhere or would it be worth investing in a proper one? If it's better to get a proper hardware encoding device can you give me some examples of what I should aim for?
I guess this is a fair assumption. I don't know which formats your box allows you to use. The best would be if you could connect via firewire and transfer the data.
Sorry to bombard you with all these questions. If you don't want to answer them all I can understand it! Once again, thanks for your feedback, it's greatly appreciated.
