Hello,
I'm trying to add the same effect (and its parameters) between all the photos and videos of the film i want to create.
When i try to tick the "use the default transition effect" box in the preferences, it doesn't work and anyway i can't add the parameters.
Could you help me ?
P.S. I use the French version, maybe the terms are not exactly the same, anyway i guess you should understand !
Add transition effects
From File-Preferences-General tab Tick- Use Default Transition Effect
Select one Default Transition Effect from the drop down box.
From File-Preferences-Edit tab-Select the Default Transition Effect Duration
The transition will be applied each time you insert a video or image clip to the main video timeline.
Existing clips will require a manual approach.
Double clicking a transition in the library will insert the transition to the first available space.
Otherwise drag and drop the transition.
I believe v11 allows you to automatically add a transition(s) to an existing project.Existing clips will require a manual approach.
Jeff
Dentler's Dog Training, LLC
