Hello Forum,
I'm having rouble installing Video Studio 11 Plus.
I am running XP on a machine with current specs.
My installation runs fine untill the "AVcontrolSDK" step, then I get a "fatal error during installation" or "installation encountererd a fatal error" message. This stops the installation. Most of the files etc seem to have been copied, but there is no program group setup in the start menu etc.
There is also no way to un-install, because there is no program group with an un-install option, and VS11+ does not appear in the add/remove programs group in control panel.
I manually removed the Ulead Systems folder from C:\program files\ directory, and tried to re-install - same result.
Replicated 3 times.
I am not running any software at the time of installation.
Any help would be greatly appreciated.
brett@magiboard.com.au
Thanks.
Problems installing Video Studio 11+
You are far from the first one with this problem. A fix can be found here:
http://phpbb.ulead.com.tw/EN/viewtopic. ... 384#115384
magiboard
