Hello,
I've got a problem with capturing HVD from Canon HV10 on Vista.
It says "Unable to switch to Capture Mode. Check if you video capture driver is working properly. [15023:4:2]"
Previously I was able to capture HDV on Windows XP using VS10+ and VS11+ and now I can capture HDV on Vista using Windows Movie Maker without any problems, but VS11+ can capture only DV.
Does somebody know how to fix this problem?
Thank you.
Cannot capture HDV (VS11+)
Vindicator
Can you import the file from Movie Maker into VS? I've run into the same problem as you, but with an HDR-HC3. Vista sees the camera and shows the driver is working properly. I got the same error message as you...camera can't capture in HD under either Vegas or VS11+.
I CAN capture under Movie Maker, and the video is flawless. However, when I try to import the .TS file, neither program can actually import it, even though I can play the file under WMP.
It's truly frustrating. I wish I knew if there was a step I was missing.
Vindicator
