i installed videostudio 9 se on windows xp 2.4 with 512 mb.
but the problem is, when i go to file-preference, i get this error message:
"ulead videostudio has encountered a problem and needs to close".
i make a format to my computer and i download and install all the updates
but nothing help.
is there anyone have idea?
uvs9 se error message
When it crashes, have you already loaded a video file into Video Studio? If you are loading a file, what format is it? (The Read This First... post at the top of the forum tells you what we need to know in order to help you.)
A bad or corrupted video file can sometimes cause a crash. Corrupt-file problems can be hard to diagnose, because a bad video file will often play-back OK, but cause trouble when you try to edit it or convert it.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
ronea
thanks for your treatment
(sorry about my english)
my capture card is "leadtek pvr3000 deluxe" (with the last driver)
the file that i use is "mpeg"
the capture settings is on "pal"
i run the vs9 on xp with 512 mb memory (free space=2gb)
i try vs9 trial that i download from ulead before, and everything was good.
but with "vs9 se dvd"(bundles software) i have these problems.
another thing is: in the welcome screen, i dont have the option "dv-to-dvd"
as i have with vs9 trial.
my friend olso have the same broblem,
by the way, i have a printscreen of the error messages, is there way to send these pictures to you, maybe it can help?
If your computer only has 2Gb of free space, that is only half the space on a DVD... If you are dealing with DV format video, that takes 13 Gb per hour of video alone. And Video Studio normally requires at least another 13 Gb space to edit and process a project. So I suspect your problem may relate to space.
As for not having the DV-to-DVD wizard, that is almost undoubtedly a result of having an SE version of VS9. SE always implies that the program has been crippled in some way, by having certain functions either limited or removed entirely.
ronea
ronea
i have 8 gb free space in drive D,
is this space can help me to solve the problem?
and how can i change the sittings so vs9 use
the drive D, if i cant get the preference?
i download a patch "Ulead VideoStudio 9 Update Pack" (18.9mb)
but i cant install it, during the installation i get the message
"setup cannot find ulead videostudio 9.0 installed on your system" why?
