Some have speculated that VideoStudio 11 Plus might be reading these files incorrectly as "frame-based" and -- as a consequence -- the render to HD MPEG-2 fails to retain fields properly.
AVCHD -- we suspect -- should be "upper field first."
Perhaps this is a flaw somewhere... either in Ulead's implementation of the MainConcept SDK or perhaps it's a MainConcept flaw.
MainConcept's Web site features an interesting comment at the bottom of this page: http://www.mainconcept.com/site/index.php?id=780
I wonder if the latter method is being used in Ulead software.When there is video footage with field-based frames (bottom field first) - such as DV material - there are two ways of encoding it:
A) Field encoding: bottom field first
B) Whole frame
The first way generates a data stream which contains field-based frames. They include the field order: lower field, upper field, lower field etc. That means, frames will be created from both fields in the above mentioned order. The second way generates progressive frames, which don't include field information. So, whole frames will always be created, and the frames will be whole.
Jerry Jones
http://www.jonesgroup.net
