Chapter Points query (VS 10+)
thebiggfella
Post by thebiggfella »
I think that the above is the right term. I'm on the work computer and unable to confirm. I'm talking about when you're editing a video in the timeline and you double click near the top of the timeline, an inverted triangle appears which I think is a chaper point. You then get the option of naming the point.
Well, I put in a few of these chapter points in a recent video I was editing thinking that I would be able to skip straight to these points when I'm watching the finished DVD but was unable to. When I checked the rendereed mpg file on the computer, it only showed as one chapter. I know you can chop footage into chapters when creating the disc, but didn't want the chapter menu, just the option of skipping to certain points without the additional menu.
I've only tried this once, so may have missed the point, but what is the point of these 'chapter points' apart from helping to locate a specific point in the timeline of footage you are presently editing? Thanks. Glynn.
Post by Black Lab »
There was a patch for VS10 that fixed this problem. Do you have the patch applied?
Peta
processor: i7 6700
Video Card: GTX970M
Hard_Drive_Capacity: C 250GB D 1TB
Monitor/Display Make & Model: BenQ 32" 4K UHD Home Entertainment Monitor EW3270U
Corel programs: Ultimate 2018/2021
Post by Peta »
Jeff
I have been searching Ulead site for a patch that covers that - I can only find Service Pack 1 dated 15th jan 2007 - is that the patch you are talking about please?
Peta
thebiggfella
Thanks for the reply. I didn't realise that this was a recognised problem. Like Peta, I can see the Ulead VideoStudio 10 Service Pack 1 (Release Date: 2007/01/14 ) which is located here. Is this the one? Glynn.
dmz
motherboard: ASUS ROG Strix Z390-I
processor: Intel Gen 9 i7 9700K
ram: 32GB
Video Card: mobo onboard
sound_card: mobo onboard
Hard_Drive_Capacity: 6TB
Corel programs: VS 2020
Post by dmz »
I stand corrected but i believe that feature doesnt work if you follow the recommended guidelines. If you have created a video file(mpegs) and then authored the mpegs then the chapter points dont work. They only seem to work if you create the dvd directly from the project file which, as you may have guessed, is a very unrecommended thing to do!
Post by Black Lab »
For the unpatched version you are correct. The patch, however, enabled the insertion of the chapter points, even when following the suggested workflow.
I can't find the post that confirms this, but you want to use the Service Patch, as referenced in the earlier post.
thebiggfella
Can anyone confirm that the above patch will enable chapter points to made at specified points in the footage but won't produce a chaper menu as is produced when making chapters when creating a disc. Thanks. Glynn.
dmz
ram: 32GB
Post by dmz »
I read about the patch and had it installed and tried the chapter point business again and it still didnt work when authoring from MPEGs. If anyone else has tried it then Id be keen to know if my result isthe norm or not.
GeorgeW
Post by GeorgeW »
dmz wrote:I read about the patch and had it installed and tried the chapter point business again and it still didnt work when authoring from MPEGs. If anyone else has tried it then Id be keen to know if my result isthe norm or not.
In the Disc Creation module, you have to also add the chapters by hitting the Add/Edit Chapter button, then using Auto Add Chapters/Insert Scenes as chapters -- this should add the chapter points you added to your VS10 Timeline.
This works for me after installing SP1 -- which set my version number to 10.0.0110.2 Plus
George
GeorgeW
Post by GeorgeW »
thebiggfella wrote:Can anyone confirm that the above patch will enable chapter points to made at specified points in the footage but won't produce a chaper menu as is produced when making chapters when creating a disc. Thanks. Glynn.
Do you want to automatically carry the chapter points to the Disc Creation module, but not have a Chapter Menu? If so, then you can do that by unchecking the option to Create Chapter Menu (in the Menu Step, hit the EDIT tab, and then under Advanced Settings, uncheck Create Chapter Menu).
George
dmz
ram: 32GB
Post by dmz »
George
Thanks. Thats very non intuitive. If i have added them once then why should i have to add them again? If you do auto-add, dont you also get other chapter points based on scene changes rather than just those you added in the timeline? What I found was that the name you gave the chapters in the timeline was ignored and they appeared as "chapterxxx".
GeorgeW
Post by GeorgeW »
dmz wrote:If you do auto-add, dont you also get other chapter points based on scene changes rather than just those you added in the timeline?
Is that what happened when you tried it :?:
tommytucker
There are two listed service packs
Post by tommytucker »
what is TBYB? The other patch is different?
GeorgeW
Re: There are two listed service packs
Post by GeorgeW »
tommytucker wrote:what is TBYB? The other patch is different?
TBYB = Try Before You Buy (i.e. download Trial).
thebiggfella
George
That's what I want to to. Thanks George.
