broken movement in the pan and zoom
tzvi
I have been putting together as a first trial a video composed entirely of still pictures-- an exercise in using the pan zoom function creatively. Its been going fine, but for some reason, the movement of the pan zoom on a couple of the pictures isn't smooth--its a broken, hesitant motion. Why would that be? How could I correct it?
Tzvi
Tzvi
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
Is the jerky motion in the preview window or the output video?
When you preview video using the preview window it sometimes appears to be jerky. This is usually because your CPU is being worked hard and may be overloaded. Try rendering the video to an output file and then viewing that file and see if the jerky motion still exists. Make sure that your PC is not working too hard by shutting down background processes such as anti-virus programs etc which use resources.
There is an excellent tutorial here on CREATING A VIDEO EDITING PROFILE which shows you how to set up a special log in which does not load processes which are not required when editing. This ensures that the processor is only looking after essential processes.
John a
tzvi
jerky panzooms
Hi John,jparnold wrote:Is the jerky motion in the preview window or the output video?
Thanks for response. The funny thing is that all the other pan zooms of stills before and after work smoothly. It is only these certain pictures that are jerky, and they are jerky in both the pan zoom window and the preview window.
What's an output file?
All the best,
Tzvi
Hi tzvi
As you may have noticed John is in Australia, its nearly 2 pm in UK, 2 am in AU, John is probably giving it big ZZZZZZZZZZZ by now.
Anyhow:- what¡¦s the difference between the images used in the jerky pan & zoom to the rest of the images.
Size Type etc.
Are you using a different Pan & Zoom?
Have you applied other filters/effects/transitions to these images
An output file
John is suggesting that you render the project to one file by Share-Create Video File.
This will create a single Mpeg of the project, it should play Ok, as a video file.
You can play this using any media player on your pc.
The render will take a relatively long time.
Regards
Trevor
Size Type etc.
An output file
Regards
Trevor
- jparnold
- ram: 16GB DDR3
I forgot to mention that when panning and zooming an image you should use the highest resolution image as possible regardless of the fact that (PAL) DVD video is 720 X 576 (pixels). Difficult to explain but take an image which is 2880 X 2304 and you want to zoom in to an image which is one quarter of the original. You will end up with an image 720 X 576 which is the resolution of (PAL) DVD video and therefore the image will not look chunky (pixelated).
Getting back to your original question (and Trevor's reply - and yes I would have been in "the land of nod") are the images all the same resolution and if not are the images which result in jerky motion lower of higher resolution of the others?
John a
Just to discard a different problem.
You do not use smart rendering with High Quality playback do you?
And if so you did not perchance EDIT the pan/zoom parameters of the offending pictures?
This my understanding of it.
I have been proven wrong on several occasions in my life. It's not going to improve.
tzvi
The jerky movement of the pan zoom on some of my stills
You suggested making an MPEG of the project. I did it (iPod MPEG-4)When I tried to play it by clicking on it, I got the following message:
"This file does not have a program associated with it for performing this action. Create an association in the Folder Options Control Panel."
I opened Folder Options in the Control Panel, but couldn't find anything that provided an opportunity to "create an association" between the folder and a program.
Any advice?
Thanks,
Tzvi
Any advice?
Thanks,
Tzvi
andywaddell
Re: The jerky movement of the pan zoom on some of my stills
Hitzvi wrote:You suggested making an MPEG of the project. I did it (iPod MPEG-4)When I tried to play it by clicking on it, I got the following message:
Any advice?
Thanks,
Tzvi
The video file should play when using Windows Media Player (providing you have the Mpeg4 codec installed on pc)
Right click the file on the hard drive, select ¡¥Open With¡K Windows Media Player
The file should also play from the VideoStudio library. A thumbnail of the video would have been placed here. Select the thumbnail and press play.
For this test you may have been best creating a normal dvd type mpeg. Select Pal/Ntsc DVD (Instead of a Mpeg4 file)
Another option would be to change the Playback Method for VideoStudio.
Using HighQuality Playback renders the project to temp files, saved in the preview folder.(takes some time)
The project is then played via the files and is usually better quality.
File¡XPreferences¡XPlayback Method¡XHigh Quality¡K.
If these options do not remove the broken, hesitant motion then¡K¡K¡K¡K¡K¡K.
We seem to be creating a big problem for such a small issue.
Regards
Ilene
- motherboard: Thimphu intel Z 170
- processor: i7-6700K quad core
- ram: 16GB DDR4
- Video Card: 6GB NVidia GeForce GTX 980Ti
- sound_card: envy audio AV - band and olfson 5.1 channel
- Hard_Drive_Capacity: 550SSD+
- Monitor/Display Make & Model: Dell Ultra Sharp 25" 2560x1440
- Corel programs: VSX8 32 And VSX9 64 and VSX10 32
broken movement pan/zoom
Hi - I'm experiencing the same issue in VS11+ - getting jerky motion on some pan/zooms on still images. All my images are 720x480 jpgs. I've used the feature in VS9 and 10+ with no issues. I'm used to seeing the jerky motion in the preview window, but it's always clean and smooth when rendered to an mpg. However I've just begun using 11+ and most of the pan/zooms are smooth but some, for an unknown reason are not. I've rendered just those portions, and have changed the pan/zoom parameters but the result is the same. I can't figure out why it jerks or stutters. I even took the same image and rendered a pan/zoom in VS9 and it worked smoothly. My work around was just to import that file into my vs11+ project but this can become cumbersome if it happens too often. I shouldn't have to revert back to older versions of VS, follow the same process and get better results.
By the way - what does the logarithmic setting do? It's checked by default.
thanks
Ilene
thanks
Ilene
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
You probably do not have the MPEG4 codec installed. Try saving the file to MPEG2.tzvi wrote:You suggested making an MPEG of the project. I did it (iPod MPEG-4)When I tried to play it by clicking on it, I got the following message:
Any advice?
Thanks,
Tzvi
Now using Adobe Premiere and Photoshop
Guy Lapierre
www.forefrontbusinesssolutions.com
Guy Lapierre
Ilene
- ram: 16GB DDR4
broken movement pan zoom
I just made a regular mpeg ( mpeg2) to burn to DVD. I always convert my project files to mpeg before outputting to DVD. Because of the broken movement I experienced in VS11, I had to revert back to VS 9 to create an mpg for the one image that was jerking in 11+ - I have no explanation for why it jerks in 11+ and works smoothly in 9. This is what I'm trying to figure out.
Again, can anyone explain what the logarithmic interpolation means? It is checked by default in the pan/zoom box.
thanks.
Ilene
thanks.
Ilene
It provides a better quality when recreating the content of the images in each frame. That's not a real accurate description but is the essence of what it does. Leaving it unchecked, and it uses Linear Interpolation.
Wikipedia Interpolation
Wikipedia Logarithm
Wikipedia Logarithm
- ram: 2 GB
- sound_card: Intel GMA 950
Here is another explanation in simple language
Logarithmic Interpolation
Ilene
- ram: 16GB DDR4
that's helpful - thanks.
However - I still don't have a explanation/soloution for the jerky motion I'm experiencing with some pan/zooms in vs11. Does VS 9/10 use linear or logarithmic interpolation. I wonder if that has something to do with it, although you would expect the results of log interp to be better.
I have a work around by reverting back to earlier VS versions as I stated in earlier posts, it's just time consuming.
Ilene
Ilene
