etech6355 wrote:Looking at the listing of files that you posted there are various formats on the dvd. I suspect maybe some of them are pictures, they all may not be videos.
Just to confirm, the .IFO files are indexing files ('InFOrmation') that store data about the disc's video files, including chapters, subtitles and audio tracks, which the DVD player looks at first to 'understand' the video files. The .BUP files are back-ups of the .IFO files (hence same size), copied to keep the DVD working in case the .IFO files become corrupted / scratched etc.
The .VOB files are basically like standard MPEG2 files, and can usually just be renamed from .VOB to .MPG in Windows and work as standard MPEG video files. (It occasionally might not work, but it will be obvious whether it has or not!)
To rename a file extension in Windows Explorer:
1. Check Windows Explorer is showing the file extensions (e.g .VOB). To turn it on if it's not, go to the Tools menu and 'Folder Options...', choose the 'View' tab, and
de-select 'Hide extensions for known file types'.
2. Copy the .VOB files from the DVD's VIDEO_TS folder to an appropriate folder on your hard disk.
3. Rename the .VOB files that are copied onto your hard disk. Easiest way is to select the file and press function key F2 (or File / Rename). E.g. Change 'VTS_01_1.VOB' to 'VTS_01_1.MPG' and when warned 'If you change a file name extension, the file may become unusable. Are you sure you want to change it?', select Yes.
You should now have working MPEG2 video files on your hard disk you can put into your editor's timeline.
I reckon VIDEO_TS.VOB is the video file for the menu screen, and VTS_01_1.VOB and VTS_01_2.VOB are the actual video files - if the original video is more than 1 GB, it gets split into 1GB chunks. If you put the 2 video files one after the other on the timeline, you
might get a slight blip between the two, but it won't do any harm.
Otherwise bite the bullet and try a newer version of Ulead Video Studio (or DVD Movie Factory would import from DVD too - it's a great DVD authoring program, but doesn't have the editing functionality of VS). Hope that helps.
Rowena wrote:thankfully mine's a silent movie at the moment
PS. won't be for long - wait 'til he/she wants a feed at 3 in the morning!
