1. Source:
Program: VideoStudio 11 Plus (GERMAN)
Source File: Movie as MPEG2-File (recorded with PCI-TV-card)
Video:
File format: MPEG2
Video type: MPEG2, Upper field first
Video size: 4:3 - 720 x 576 (PAL-Standard)
Frame rate: 25.00 frames / sec
Data rate: Variable (Max. 4038kbps)
Audio:
Audio type: MPEG2 Audio
Properties: 48000Hz, 16 Bit, Stereo
Bit rate: 192 kbps
2. Project-settings:
MPEG-Files
I manually set the project-settings to be the same as the source:
Video:
File format: MPEG2
Audio:
Bit rate: 192 kbps
3. Creating a MPEG-2 File (NOT PAL DVD)
I tried every possible share settings (file format: MPEG2) to create a file that is like the source file (File format: MPEG2 - NOT PAL DVD):
Tested share settings:
- Same as project-settings (result: PAL DVD)
- Same as first video (result: PAL DVD)
- MPEG-Optimizer (result: PAL DVD)
- PAL MPEG2 (result: PAL DVD)
- Custom (with same settings as source) (result: PAL DVD)
So, it seems to me that's only possible to create a file with the following properties:
file format: PAL DVD
video type: MPEG2
Creating a file with
file format: MPEG2 and
video type: MPEG2
seems to be NOT POSSIBLE.
I hope that someone can help me with this problem.
Otherwise I will go back to VideoStudio 9 or 10
