How can I change the project settings to the correct fps
oceanauk
I'm using MovieFactory 5 and editing mpeg movies which are 29.9fps but the settings on the software show 25fps. I've tried changing them but the settings tap which has this information is greyed out. Any help please? Many thanks
Goto "Preferences" and change your "TV System" to your choice, NTSC or PAL.
But it should be set to the correct default settings. Not sure how this will affect templates and other settings in MF5. You should manually set your project settings to match your source videos properites by using the customized feature. "Gear Icon -> Change Mpeg Setttings -> Customize"
Change the "TV System" first before you change the project settings.
