Videostudio 10+ crashes when trying to create a videofile
Erik1967
Post by Erik1967 »
I've finished a project in vs10+ and I want to create a mpg file (using tab Share -> Create Video File), but unfortunately, vs10+ crashes when trying to create the .mpg video file.
The mpg file should be in DVD-format, 8000 kpbs variable bit rate, mpeg audio.
So the question obviously is: how do I prevent the crash?
Note:
- this problem does not occur when trying to create videofile from other projects. So the project is corrupt?
- the error in the eventviewer is:
Faulting application vstudio.exe, version 10.0.0.0, faulting module mpegin.dll, version 1.1.1.168, fault address 0x0005d8cc.
Jerry Jones
Post by Jerry Jones »
Visit the Memtest86 Web site.
Download the test.
Test your ram to rule out the possibility that you may have some bad memory.
http://www.memtest86.com/
If your ram passes the test, then you can move on to other possible reasons for the crashes.
Jerry Jones
http://www.jonesgroup.net
Gateway 7426gx
http://tinyurl.com/hagye
Erik1967
Post by Erik1967 »
Thanks for the reply. I've carried the test but to no avail.
It seems to me the project is corrupt. I rearranged some of the clips and then problem did not occur anymore. But the original project still continues the crash. I would be nice if there's a way to get rid of it.
