i noticed that this is in the tutorial section but i posted there and it hasn't been replied to so sorry if this is in the wrong place. also that thread was on version 10.
i cant seem to figure out how to do this easily. coniguring the overlay track would be i would have to follow the number plate at every second, is there an easy way of day this.
i also was wondering whether i could crop the video clip as not everything shown was necessary.
thanks in advance to any help.
Bluring (faces/number plates)
If you are unable to use the method described in Steves Tutorial for some reason then you might like to try the 'Moving Parts' plug-in available from here :-
http://www.stagetools.com/
Asian89
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Camouflage
have a look at
http://phpbb.ulead.com.tw/EN/viewtopic. ... 697#107697 and
see if anything there helps Ken
have a look at
Never known that to be a problem before - VideoStudio usually opens files from previous versions without problems - especially files that are from only two versions earlier.Asian89 wrote:steve's tutorial didn't work because it was an earlier version therefore i couldn't view the file.
You do realise that the downloaded file is a .zip file and needs to be "Unzipped" into a .vsp before it can be used in VideoStudio don't you
Steves not around right at the moment and I don't have version 11 - perhaps someone who does have version 11 can see if they can open Steves .vsp into V11 - download the .zip file from here :-
http://www.steve-jones.pwp.blueyonder.c ... lurvs9.zip
I found out a workaround.
In VS11+ load the blur01.vsp. I had playback set to high quality so it would render to a temp file before playing back. Once this was done, I then went to open blur02.vsp. I was asked of course if I wanted to save my changes to blur01. I had not changed anything, however I chose yes.
Blur02.vsp opened, and I was then able to use blur01.vsp. I have no idea why.
