VS9 AMATEUR
Ladislaus
motherboard: Asus P50L-E
processor: Intel Core 2 Duo 2.80GHz
ram: 2.8GHz 2GB
Video Card: NVIDIA
sound_card: Sound Blaster Audigy
Hard_Drive_Capacity: 222+ext-1T
Post by Ladislaus »
Regarding my immediate previous posting seeking help with multi trimming I was succesfull the 5th time.
I now wish to insert text using'colour' screen with some information.
I did this by dragging the 'colour' clip between 2 clips but when tested the text appears written over the ensuing clip. Please advise how to overcome this situation.
Thank you
It sounds as though you have applied some sort of animation to your title, such as a fly in and out or a scroll from bottom to top but could you confirm that please?
And of course, if you are wanting to do it against a colour matte background, then the latter has to have the same duration as the title with the animation. In timeline view, you should be able to see the title in the overlay/title track. The colour matte you insert in between the clips in the main track merely has to be extended so that it matches the end of the title clip. Just highlight the colour clip and change the duration with the clock or if you can, simply click on the heavy yellow bar at the right end of the highlighted colour matte and drag it to the right so that it now matches where the title ends.
Make sure you have ripple editing enabled.
Ladislaus
ram: 2.8GHz 2GB
Video Card: NVIDIA
Post by Ladislaus »
Thanks again Ken,
I did not apply animation,flyin/out or scroll
How does one enable 'ripple editing.
Thanks.
Well if you didn't apply an animation, you only have to make sure the title overlay stays exactly in line with the colour patch in the main track.
As for ripple editing, again in timeline view, it is to the immediate left of the top track. Hover your mouse over the little icon and it will show Ripple Editing. You click it on and off. When it is on -- and you have to enable it for each track -- everything to the right of the insertion point will move to the right.
Ladislaus
ram: 2.8GHz 2GB
Video Card: NVIDIA
Post by Ladislaus »
Thanks Ken,
Having followed your invaluable guidance, I checked the project in 'Instant play back' and seems excellent.
Do I now have to
1. Change to 'High Quality play back'
2. Render
3 Create video file
before burning, which I would like to do in MF4.
Thanks again
1. No.
2 & 3: they are one and the same thing. Share > Create Video File > DVD means that you are rendering your project into a DVD compatible mpeg-2.
Once you have it, save your project, and close VS. Then open MF and use the mpeg-2 in that to burn your DVD.
Good luck! :lol:
