When I save an image, I select Invoke Options and rely on the Image Optimizer to let me know how big the file I'm saving will be (for web images). I've recently upgraded from PhotoImpact v8 to v12, and I'm finding that the projected file size as displayed in the Image Optimizer is no longer accurate at all.
For example, when the optimizer says the file will be 15kb, the actual saved file may be 23kb, which is 50% bigger. This was not a problem for me in v8, nor is it a problem in other graphics programs I use. Is this a known issue?
Thanks in advance
Displayed file size on save different than actual size
- VikingAnimations
- processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
- ram: 4 GB
- Hard_Drive_Capacity: 1 TB
- Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
zipzip
- VikingAnimations
- ram: 4 GB
Not that I've been able to locate.
I tried resizing an image from a camera, and had no discrepancy like you did. The saved size was the size indicated, to the byte.
You could email me the original image, and tell me exactly what settings you are using so I can try to duplicate the issue on my end... or dig further into the mystery.
zipzip
zipzip
