Hi, I have downloaded the trial version of VS and i am trying to convert my analog s-vhs tape. I follow the recommended procedure but it seems to leave out one crucial step - the video compression. If I try to capture the video without selecting the video compression (in the Video and Audio Capture property settings) then there is a black clip in the editir. But if i select a software compression (such as Microsoft Video 1) it starts to capture ok and i can see it in the edit screen.
Problem is i can find little documentation on this in the manual.
All i want is to be able to capture my analogue video with the best quality. I am not sure this compression is the best way as the quality seems to suffer when i switch it on.
Anyone any ideas please ?
Cheers
What video compression to use (for analogue)
Dom
THoff
For the best quality, you would want to select a codec that is lossless, or nearly lossless. One of the most popular lossless codecs is HuffYuv -- it can do realtime compression with about a 2:1 to 3:1 ratio with no loss of quality.
Not everyone needs lossless compression, and some would rather trade a small degradation in the video for additional disk space savings. In that case, I would go with DivX Free or XviD.
Whatever you do, do not install some "codec pack" that bundles a ton of different codecs (with often overlapping or conflicting capabilities) into one installer -- this will likely cause more troubles than it is worth.
Dom
THoff
THoff
