Unable to Load Library
zvfink
Post by zvfink »
I am using the trial version of ULEAD videoStudio version 11.
When I try to render the video/slide show, it stops at 7% and says unable to load library. 19151:3:3.
What should I do?
jeremyalyea
Post by jeremyalyea »
I am having the exact same issue. Anyone have any ideas? I have about 200 photos and 6 short video clips that I am trying to combine into one movie with transition effets between all of them.
Bruce5m
motherboard: Dell Inc. 05DN3X A00
processor: 2.80 gigahertz Intel Core i7 930
ram: 12GB
Video Card: ATI Radeon HD 5800 Series
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Samsung SyncMaster T220
Corel programs: VideoStudio Ultimate 2018
VS11 Plus - Unable to Load Library
Post by Bruce5m »
jeremyalyea wrote:I am having the exact same issue. Anyone have any ideas? I have about 200 photos and 6 short video clips that I am trying to combine into one movie with transition effets between all of them.
I purchased VS11 Plus today as an upgrade to VS8. It seems to work really well during edits and previews. But, I have run into the same issue. I get the "Unable to Load Library" error when part way through the rendering process.
Bruce5m
ram: 12GB
Re: VS11 Plus - Unable to Load Library
Post by Bruce5m »
Bruce5m wrote: I purchased VS11 Plus today as an upgrade to VS8. It seems to work really well during edits and previews. But, I have run into the same issue. I get the "Unable to Load Library" error when part way through the rendering process.
I isolated the problem by watching the preview screen as the project rendered to identify the point in the project where the "Unable to Load Library" error occurred.
I found that the error occurred when the project hit a 3D transition called "Flying Flip". To that point in the project, I had used the F/X transition called "Cross Fade" with no problem.
Once I removed the "Flying Flip", my problem was solved and the rendering process was able to complete without error.
I am guessing that the transition library was corrupted during the installation process. If multiple people are having this problem - perhaps it is a problem with the VS11 installation routine.
Cheers
jeremyalyea
Cheers
Thanks Bruce. I think you are on to something. In fact all of the "Flying" transitions are corrupt in my version. I am watching the file as it is rendering and each time it gets to a 'flying' transtition I get this error.
Jim Viola
Same Error [19151:3:3] with VS9
Post by Jim Viola »
I am getting the same error with VS9 but have not isolated it as of yet to
a transition problem.
I have an open post with the Forum.
jim
adrienne
Post by adrienne »
Same problem with the flying transitions here, with full version of VS 11+.
adrienne
Post by Black Lab »
Will someone with this problem please submit a Technical Support Form.
teleoma
motherboard: X99-S
processor: Intel i7 5820K
ram: 32 GB
Video Card: Radreon R9 280
sound_card: Realtek High definition
Hard_Drive_Capacity: 5 TB
Monitor/Display Make & Model: Asus MX299 and Dell 2407WFP
Corel programs: Video X7 Ult PaintShop pr0 Ult
Post by teleoma »
I have the same problem with VS11 +, online purchase from Ulead, with all flying and album transitions. It happens on my vista ultimate computer but also on my XP computer.
I fill a technical request by the ulead support team. When/if getting any answer, I wil post it hier.
Regards
Martine
teleoma
motherboard: X99-S
ram: 32 GB
Post by teleoma »
When I saw that quick time manually must be downloaded and installed for smartsound to be working I decided to install the applications of the bonuspack I first didn't intent to use.
After installing WinDV 8, included in the bonuspack of VS11+, all the transitions seems now to work in VS11, included the flying and albums transitions.
My OS is Vista 64bit ultimate
Regards
Martine
meug
error
Post by meug »
indeed leave away any 3D effects and it works
looks like ulead have a job to do
and i hope they do it quick
teleoma
motherboard: X99-S
ram: 32 GB
answer Ulead Tech
Post by teleoma »
I just got the answer of Ulead.
Question/Problem: When using flying transitions from the 3D library or any of the transitions from the album library, I can't see a preview of these transitions in the preview window. When clicking on "customize" in the effect tab window I get every time the error "unable to load library 19151:3:3". I got this error also when rendering, no matter the format of file to be created.
Please download the following files and install them in this order:
1. Microsoft .Net Framework
http://www.microsoft.com/downloads/deta ... laylang=en
2. Microsoft Visual C++ 2005 Redistributable
after installing, restart PC then reinstall MovieFactory
Case #62855
Regards
Martine
