Fatal error when trying to install trial version of VS11+
Image Master
Re: Fatal error when trying to install trial version of VS11
Post by Image Master »
Hi could you please answer me two quesitons:
1) Is there any other Ulead and IVI software installed in the same machine, if so please list them out.
2) Have those user ever installed any Ulead or IVI software before? If so please list them out.
thanks.
Svuppe wrote:Hi. I am a long and happy user of VS (from version 6). I skipped version 10, but now I wanted to have a look at the new version.
But I can't install it. It seems to install a lot for a while. Then it kind of hangs for some time, saying: "AVControlSDK is being installed, please wait". And then suddenly it says "A fatal error has occurred while installing". I press OK, and the installer exits.
Manually browsing to the install dir, I see a lot of installed files, so I try to run vstudio.exe, but it just say "Unable to load the library 'TBYB'."
I have tried to remove every last trace of the failed installation attempt, as well as clearing up various Temp and application data directories, and then reinstall. Same error.
I run Win XP SP2, I run as Administrator and I do not have any antivirus software running. I do have VS9 installed, but I don't think that should interfere with the installer. Any bright ideas?
Could all Members who are affected please view:
avcontrolsdk - Your Help is Required.
Thank you - Steve Jones - Forum Administrator.
Svuppe
Post by Svuppe »
Image Master wrote:Hi could you please answer me two quesitons:
Of course. The answer is in the other thread, Steve pointed us to.
DiscoLED
Post by DiscoLED »
Svuppe wrote:Now I have tried it, but that didn't help.
However, I then went a step further. My suspicion has been around the installation of AVControlSDK. So I poked around a bit in the now unpacked files, and in Info.ini i found an entry called AVControlSDK=1. I changed that to 0, and tried yet another install. And to my big surprise it got all the way through. After that, I installed AVControlSDK by manually running Utilities\AVControlSDK\AVControl.exe
And now VS11+ trial works on my machine.
Such a kind of installation causes an absence of a "capture plugin" with VS!
Videostudio 10plus
ennastu
have similar problem with fatal erro during install
Post by ennastu »
I tried following your suggestion because I have this same problem. I am unable to locate the Info.ini or the AVControlSDK files. I looked in the unpacked files and don't see anything remotely close to these. Please advise.
Svuppe
Re: have similar problem with fatal erro during install
Post by Svuppe »
ennastu wrote:I am unable to locate the Info.ini or the AVControlSDK files. I looked in the unpacked files and don't see anything remotely close to these.
Strange. What file have you unpacked and what do you then see?
ennastu
Post by ennastu »
oops. I guess I unpacked it wrong. Now that I download Winzip trial version, then uppacked. I found everything just fine. I followed your steps and it now works!!! Thanks for the easy fix. Hoepfully I like the new version.
akcub95
help
Post by akcub95 »
I have tried everything suggested and am still clueless. I opened it in winzip and finally found the info.ini and TRIED to change AVControlSDK to 0 and saved it and closed it. Reopen it and it's back to 1...I'm going in circles and about ready to ditch the whole thing. I want to try it before I buy it and all this is doing is changing my mind. Can someone help?
Thx
When you sy you opened it with winzip - do you mean you EXTRACTED it with winzip. Opening it and changing the file concerned only affects a temporary file - not quite the same thing.
akcub95
Post by akcub95 »
Well, I opened it with winzip and then changed it and then hit extract. I'm such a novice at this type of stuff, I'm not sure what I'm doing wrong.
Thx
akcub95
Post by akcub95 »
Well, I figured it out and it seems to be loaded correctly, but I haven't gotten it to "capture" any video yet, so I will play around until I can figure that out.
Thx again
I have received the following email from Ulead.
Dear global support team,
As you know users encounter a bug regarding installation error of UVS11 and DMF6. During installation they suddenly got the error message "A fatal error has occurred during installation". after the message "AVControl SDK will be installed". Every known solution in that case won't change a thing.
The patch for this bug was ready yesterday, please send the attached file or this link to user.
ftp://ftp.ulead.com/pub/Updates/VideoSt ... pgrade.exe
The steps are listed as following,
1. Remove manually the UVS/DMF files/folder under Program Files or where they installed by themselves.
2. Update the patch WinDVD5.0B011.Recover.FixedGenericLicense.iUpgrade.exe
3. Install UVS/DMF again.
Please give me any feedback of users, if it runs ok, I will require web team to create webpage for this patch.
fopi
Post by fopi »
Hello!
So what is new about dealing with this problem?
If I use WinDVD5.0B011.Recover.FixedGenericLicense.iUpgrade.exe I get the same problem as some of the people saying that the program can't run because I don't have WinDVD...
I'm still waiting for the solution.
