During the creation of a DVD, I encounter "Unspecified Error 5:0:0". When I hit the "Back" button, I get "Out of Memory"
I am using VideoStudio 10 Plus with service pack 1 (Full version as a download)
The failure usually occurs when the total progess is at 99% (after the menu creation).
The DVD to be created contains 7 clips.
Each clip have chapters automatically created.
Menus do not have any motion, but does have background music.
There are no Menu In/Out transitions.
The DVD is being written as an ISO and not to a DVD
The total DVD size is 3.85GB (1hr 4mins 19secs)
Video files were rendered in VS10+ with the following options:
24 bits, 720x480, 29.97 fps
Lower Field First
NTSC, 16:9
Video data rate: Variable (8000 kbps max)
Audio data rate: 448 kpbs
Dolby Digital Audio
I am using the Video Editing profile as outlined in this forum and I am creating the DVD with an empty project. I have followed the recommended DVD creation procedures.
I have tried this on 4 different systems w/ the same results. I am able to create DVD images of each video individually.
Any suggestions?
Any way to run VS10+ in "debug" mode?
Unspecified Error 5:0:0 during DVD creation
Sounds like it has something to do with the menu, but usually you get the Convert Step Has A Problem error.
Have you tried burning using a different menu, or without the music?
What type of background music is it? MP3s can sometimes cause problems. Converting to WAV often helps.
Sometimes overlapping buttons or text that overlaps buttons on the menus will cause problems.
Jeff
Dentler's Dog Training, LLC
I tried using one of the thumbnail menus (05vs_Sce_B04_w) with no motion menu, default background music, no menu in/out transitions and it still failed with the same "unspecified error 5:0:0" and "out of memory" message when I hit "Back".
Again it is failing right after creating the menus (before doing the video/audio multiplexing).
I have also tried it without background music and that failed too.
What is interesting, vstudio.exe is using 1.5GB of memory when the process fails. Should it be using 1.5GB of memory?
Is there a memory leak in this program?
I did try using a text menu (05vs_Text03_w) and interestingly enough that created with no problems.
Any other thoughts?
Thanks,
Polly
Any other thoughts?
Thanks,
Polly
I am finally able to successfully create the DVD image using the 7 clips by reducing the number of chapters in one of the clips which also reduced the number of menus.
I originally had over 200 total chapters and about 55 menus.
Now I have a little over 100 chapters and about 30 menus.
Is there a limit as to how many total chapters/menus can be created?
Yes. You can have up to 99 chapters per video clip. Perhaps you exceeded that on one of your clips.Is there a limit as to how many total chapters/menus can be created?
Jeff
I get the exact same error.
I am creating a DVD with VideoStudio 11.
Creating a DVD with or without a menu makes no difference. The error always occurs at 99% completed (=very frustrating).
When I just bought VideoStudio and had not yet installed the additional Content Pack, I also created a DVD. This worked without any problems. After installing the additional Content Pack, it does not work anymore.
Might this be the cause or just coincidence?
when looking at the output log files I find the following results:
BurnFlowMgr.txt:
Burn Flow Report, Date Sunday, May 13, 2007, 12:22:08
Start do output action : Pre-check action
AP project GUID : 0b30bf12-0332-4918-b952-a12974a159a6
Core project space : 2884632576 byte
Media check ok
DiscLayout clone ok
Project total segment count : 0
Project total titla count : 1, Pass title space check : 1
Project total menu page count : 0
DVD Spec. limit check ok
Total title convert step count : 1
Total menu convert step count : 0
Total burn step count : 3
Total step count : 4
Start burn folw action
output file failed, Error : 0
disc compile fail
playlist.txt:
Kernel engine create ok
Start do playlist create
Multi language count : 1
Language 0 type : 25966
Set MLU success
Set volume data success
Total volume number : 1
Focus volume ID : 1
Volume side ID : 1
Volume region code : 0
Volume media flag : 1
Volume layout type : 0
Volume provider ID : (null)
Start to fill First Play Title(s)
First Play Title(s) fill ok
Start to fill Title(s)
Video Title ID : 6c4533af-32b2-47ef-a13b-6a10ac201996
Start to prepare video angle content : 6c4533af-32b2-47ef-a13b-6a10ac201996
Build video track
source file: L:\Ulead VideoStudio\11.0\DMF_TEMP\CvtedTitle\May13_1222x000RR TAY_7900.mpg
markin: 0, markout: 268610
Chapter count : 8
Title chapter ID : e028fbb1-e52a-453a-b938-f8f88f9c02a1
Chapter index : 0 frame, bIsHideChapter : 0
Title chapter ID : e446d5a5-7405-4bd0-ad04-489fa24b902c
Chapter index : 41218 frame, bIsHideChapter : 0
Title chapter ID : 46b02958-0f7c-4a4c-b5f5-34e1b7d33453
Chapter index : 62512 frame, bIsHideChapter : 0
Title chapter ID : aac4568e-a20f-441b-b974-68bd93a4ef86
Chapter index : 77586 frame, bIsHideChapter : 0
Title chapter ID : 85a07b71-7636-450d-adaf-eca86e636ac7
Chapter index : 113761 frame, bIsHideChapter : 0
Title chapter ID : 3ffdab77-8b29-450f-99c2-794699aa0e9c
Chapter index : 146870 frame, bIsHideChapter : 0
Title chapter ID : 9dde6447-c421-41bd-8aaf-70521508d528
Chapter index : 187274 frame, bIsHideChapter : 0
Title chapter ID : 2422778c-e13f-45e3-9e5f-b18456c289a8
Chapter index : 243118 frame, bIsHideChapter : 0
Build audio track part
Audio track count : 1
Get Audio file data fail, Audio track 0 source file:
Build audio track failed
BurnFlowMgr.txt:
Media check ok
DiscLayout clone ok
disc compile fail
playlist.txt:
Set MLU success
Focus volume ID : 1
Volume side ID : 1
Build video track
Chapter count : 8
