Come on guys!
I HAVE TESTED THE CLIPS ON THREE COMPUTERS, EACH USING WINDOWS MEDIA PLAYER 11 AND EVERY ONE OF THEM SHOWED THE SAME PROPERTY PANE DATA!
It is not about WMP11's 'playback problems', because the very same "manipulated DivX' versions played back nicely in full screen mode, 16:9 ratio, and so did the standard MPEG4 and DV clips!
I sent the files over to a friend of mine in Europe to have him play back the clips on his machine, and got back the same exact results! The first clip didn't even play, stopped at 1 sec for him as well! The rest showed those freaky values with the 1088s and the 4:3 ratios.
Are you telling me that all of these, now 4 (!!!) computers have huge codec issues, must change this, that, hardware, bla-bla-bla, everything??? NO WAY!!!
The Sony laptop is on its way, in the afternoon I'll be able to post the results.
- First I'm just going to try to play the clips I rendered on my computer,
- Second, I'll play the ones I rendered on the other machine,
- Third, I'll install the software and render similar clips in all possible variations and settings back and forth...
- Then I'll play them on the Sony,
- Then transfer the latest clips to my computer and check the playback details.
- Then I'll post everything here.
The other suggestion that the clips should be checked in VS11+ environment, doesn't make too much sense, does it? I mean, you try to verify that a software indicates and renders with wrong values using the same 'faulty' software which shows 'seemingly' correct values, that translates to wrong ones outside??? It is nonsense! VS11+ shows everything to be perfect, but the software is faulty and the indicated values are faulty, incorrectly translated/indicated/created, and show the proper values only in its own environment, not outside with WindowsMediaPlayer, which immediately verifies the problem and indicates the true values. Not even mentioning that WinMP is what most users have.
OK, the answer to the other issue of Importing Files:
- My camcorder creates *.m2ts files that VS11+ DOES NOT recognize! So, it is NOT a "fully AVCHD compatible" software in the first place. I had to convert the files from the *.m2ts format to *.m2t, otherwise I've got the "file mismatch/unrecognized' error from VS11+.
- I've run the test you suggested, modifying the properties to indicate first clip "match settings", but the created clip didn't even ask for it. I closed and re-opened VS11+, inserted this clip as the first clip, but the software didn't show any pop-up box. It only asked for it when I tried to insert one of the previously created clips. I did click "YES" and of course VS11+ property pane showed the correct values and ratio....
BUT!
It always shows the correct data INSIDE the software, that's not a surprise for me, that's why I said it time and time again, that the problem is with the OUTPUT! Inside everything is peachy, beautiful, perfect, I never had any problems using, modifying, setting, changing parameters, etc... but the output shows the same mismatch/problem and error (first clip that didn't even play) on EVERY testing computers with Windows Media Player 11!
So, I believe that the software produces clips with either incorrect parameters that the most widely used media player (WMP11) verifies to be faulty, or there is a compatibility issue with this, as well as other players, such as RealPlayer, which I tested and showed the same problems!
The 1st clip didn't play on RealPlayer either, the 4:3 clips played as such, not widescreen but a narrow box, and the only ones that played correctly were the Standard DVD Def clips that WinMP also recognized and indicated to be correct 16:9, and my manipulated/cut DivX Hi-Def that also indicated the correct ratio and values in WindowsMedaiaPlayer!
EXACTLY WHAT I EXPECTED!!!
So, RealPlayer just verified to me that in fact, the created clips may 'look' correct in VS11+, but the output clips don't play properly on RealPlayer either! Or rather, they, in fact, do play properly, because they are actually 4:3 ratio clips, no matter what VideoStudio within its own environment shows or says!
So, as it stands now, I've got 3 Media Players verifying the problem:
- Windows Media Player 11
- Real Player 10.5
- DivX Player 6.4.3
- Yes, DivX Player also couldn't play the #1 clip, just as WMP and Real couldn't!
- Yes, DivX Player also displayed distorted 4:3 clips instead of widescreen 16:9 format!
- Yes, DivX Player also showed the 'black TV stripes" on the Hi-Def DivX clip.
- Yes, DivX Player also played back my 'cut' DivX Hi-Def clip correctly!
ALL THREE JUST VERIFIED THE OBVIOUS!!!
I T I S A S O F T W A R E P R O B L E M ! ! ! ! ! !
PS: And what's with that 1088 anyways??? This is the "new and acceptable standard" suddenly??? Next time it will be 1084, 1090, 999.8 because of this and that, bunch of meaningless explanations and excuses that it is 'just a programming thing"??? It also indicates correct 1080 in VS11+ yet it clearly shows 1088 outside??? I mean, how many clues do you need to accept the fact that we've got a very serious encoding problem with this software's output and inside translation of the faulty values???
I've got yet another new idea how to 'prove myself wrong' once again.... I'll be back with the results....
PS 2: Just as 'you don't have to be a good actor to recognize a bad one"...the same way... 'you don't have to be a programmer to recognize a faulty software' either....
