So, the 'big wait' is finally over, VS-11 Plus is here!
I was waiting for this product, but instead of a solution I've got another disappointment!
The reasons: (It is very hard for me at this moment to stay civilized after hours and hours of frustrating trials, but I try...)
1 - I had VS-10Plus which was advertised as a 'true hi-def editing' software, but it was unable to recognize my Sony's AVCHD - *.m2ts format. I was told that this new version will be able to handle it, but it cant! I spent hours figuring out just how to convert the *.m2ts files to *.m2t, which I finally managed with pain and suffering... with a "reach your left ear with your right hand" sort of solution...
2 - OK, now that I've got the 'proper' file format, I've run a few short tests. I was desperately trying to create a simple 6 second Hi-Def clip in 16:9 ratio, but so far NONE of the settings were able to do that, every stupid settings creates 4:3 ONLY with those annoying black top/bottom lines that I don't want or need. All settings from the beginning are set correctly to 16:9 but no use...
3 - When I create a "HD DVD" clip in *.mpg format only a 2 second clip was made, the rest is gone.... Of course, it rendered the 'final product' in 4:3 instead of 16:9....(... in both 1440 and 1920 versions...) ...
4 - In HDV format the entire 6 seconds were made, but again, in 4:3 ratio...
5 - DivX in Hi-Def got the whole 6 seconds, but again, in 4:3 ratio...
6 - WMV format did the same, with 'good old' 4:3 ratio... and the annoying black stripes on top and bottom...
And those who wonder, I've checked (many times) and I did set everything properly, the clip was shot in 16:9, the project is set to 16:9, the saved files were selected to be 16:9, but the output is always 4:3 and on my opinion, just regular "DVD video" size, not Hi-Def size!
The ONLY half-success was when I set custom Mpeg-4 to regular 720/480 format which created 16:9 ratio, but then again, in regular format and not in Hi-Def, because Mpeg-4 does not allow Hi-Def 1440 settings.
It is strange though that the 720/480 video showed exactly the same size on the player (set to 100%) as all the other "Hi-Def" rendered clips, so, once again, on my opinion, all the video files are the same DVD size and NOT Hi-Def size! It is easy to compare with the Sony software/player to play a clip in full size and the difference is obvious and unmistakable!
So, what now????
Contact Tech Support or just ask my money back???
