I have completed sucessfully two HD-DVD projects with DVD Movie Factory 6 Plus which I purchased and downloaded three days ago. Last night I set up a third project with exactly the same settings as my previous two projects that were succesful. The only difference was that I checked "Create HD-DVD Folders" and "Burn image file" but I did not select "Create Disk" in the Burn Window since I have found that this does not work with dual layer disks which have to be burned in Nero. When I came into the computer this morning I had "unspecified error" and nothing was saved to the HD. I rebooted my computer, and ran the project again. Several hours later I received the "unspecified error" message again. I read the threads below on this and have found others getting this error, but I did not see anyone who sucessfully figured out what is producting the error. Does anyone have any suggestions?
Tom
Movie Factory 6 Plus Gives Unspecified Error
tnw2933
I am pleased to say that I was successful the third time in completing this project in Movie Factory. The only change that I made was to uncheck the 2-pass conversion within Movie Factory. Once that was done the entire project executed sucessfully and I burned a dual layer DVD+R from within Nero (since Movie Factory does not correclty handle layer changes). the disk played fine from beginning to end in my Toshiba HD-A2 HD-DVD player and I could not detect any loss in quality or motion artifacts from having turned off 2-pass VBR.
Tom
Tom
