Creating HD-DVDs with H264 video problem (MF6)
dattrax
Post by dattrax »
After a lot of messing around I managed to make some HDDVDs which play in my standalone without DVD Moviefactory deciding to recompress!
Now onto my next project which is using h264.
I've created a transport stream with h264 and with AC3, but when I try import, the whole thing locks up (import dialog goes not responding)
Wont import native .h264 files and then let me add the audio, needs to be a multiplex.
h264 cant be multiplexed in a program stream (or at least thats what I remember) so I cant turn the transport stream into a .mpg
Has anyone succeeded at this?
If so, what was your work flow?
Cheers
Jim
etech6355
Post by etech6355 »
What was your workflow so MF wouldn't re-compress?
I know of a program that can insert the H264 files directly and if you have the correct H264 codec installed MF6 can also do this.
dattrax
Post by dattrax »
At first I tried to insert elementry streams, but it would always recompress. I then tried a .mpg file, but no luck with that either.
I used a program called HDpatch to fix up the bitrate and frame sizes and this did the trick.
I'm just trying to repeat the experiment with h264 encoded material
