Help - my video shrunk!
Crein76
Post by Crein76 »
I'm a new user to Ulead...I'm working on editing a video with ULead Video Editor 7.0. My video was in wmv format when I imported it. I made my edits and then saved it as an mpeg. After saving, I re-squeezed it (using Sorenson Squeeze) to compress into a wmv file again.
When I watched my end product, my video had shrunk from its original size...any thoughts on how to keep the video from shrinking when creating a video file? Is there any format that needs to be changed within ULead itself?
Any help is GREATLY appreciated!!!
MonroePoteet
Make sure resolution is set correctly
Post by MonroePoteet »
The output resolution is determined by the Project Settings. Before doing your final render, use File=>Project Settings to determine what resolution is going to be produced. If it's not what you expect, change it using the Edit button and the General tab.
mTp
Crein76
Post by Crein76 »
Thanks - I'll try that!!
