tommytucker wrote:Having no luck burning directly from project to DVD, I have followed advice to create a video file first in MPEG format, then open a new project, insert MPEG, create menus, etc and then burn. Since I only want my finished burn to be of highest quality I was still confused by a few things. When I create video file, I am not sure WHICH MPEG format to use. There is MPEG 2, NTSC DVD, MPEG 1. I believe the bitrate should be 8000. I just want to render the file to the best format so that when I insert the finished file, I will have a quality burn for that DVD viewing on a Plasma 720p/1080i set. Second issue, what would possibly trigger a dreaded 'rerender' after inserting the video file MPEG into the burn phase? If you make any edits in the MPEG video file that you inserted after creation, would that cause a rerender even with Compliant box ticked? How about an overlay, title or audio in one of the overlay or music voice tracks? THANKS!
Over the past 4 days you have asked the same question, even high-jacking this thread. Your questions have been answered numerous times and you've been given links to the suggested workflow and tutorials.
So we'll try again... You don't say where you are, but since you reference NTCS DVD I'll take a stab that that is what format you will be using. Yes, if you will be making a DVD to be used in an NTSC country, use the NTSC DVD template.
DO NOT make any edits to your rendered MPEG. Make the edits to your VSP file, then re-render to another MPEG. Since your source files are AVIs there will be no loss in quality. Re-rendering the MPEG will surely cause some loss.
