I can't make MovieFactory to import a DVD or a DVD-folder. I can open the "Import DVD"-window and click on "Title 0", but the import-button remains gray and inactive no matter what I do.
I can play the video in the movie-window, so I don't understand it.
TV-system is PAL.
Ihave the same problem with both version 4.0 and version 6.0 of MovieFactory.
What is wrong?
Will not import DVD
If your DVD was made with a stand-alone DVD recorder, or with a camera that records directly to DVD, make sure the DVD is "closed" or "finalized". (This is done on the recorder/camera.)
Try copying the DVD to your hard drive before importing it.
If that doesn't work, you can try FixVTS or VOB 2 MPG (both FREE!!!).
If it's a commercial DVD, its copy-protected.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
hiddenfeldt
Additional info
The DVD-folder was made by the following programs:
DVB-T-signal received by Hauppauge HVR-1300 or HVR-4000 HW recorded by www.dvbwiever.com to a video_ts(.ts) file.
Then ts-file->MPEG_Streamclip->ProjectX->Rejig, that makes the DVD folders.
(The reason for ProjectX and Rejig is to make a DDV with subtitles.)
I have also tried with a DVD made by Ulead MovieFactory 4.0. Also in this case the import button remains gray. The DVD plays well in a DVD-player box.
I have not attempted with any comercial DVD.
I wil try your tips asap and return with the result, thanks.
hiddenfeldt
sjj1805 wrote:Are we overlooking the obvious.
Did you tick the little box(es) in the left hand column of the chapters you wish to import.
I guess he did...
hiddenfeldt wrote:I can't make MovieFactory to import a DVD or a DVD-folder. I can open the "Import DVD"-window and click on "Title 0", but the import-button remains gray and inactive no matter what I do.
What is wrong?
@hiddenfeldt, can you reinstall the software first and be sure that you have Admin privileges to the PC you are working on.
Also, plese try another DVD (closed and not copy protected)
Thanks.
hiddenfeldt
