Shadow on the sphere
Eduardo_B
Okay, I've modified the default movie with the text rotating around the sphere (earth) and now see that it lacks the realistic final touch of a shadow on the sphere from the text. I've tried the shadow plug-in, but can't get the effect I want. Is this doable?
dnavarrojr
Re: Shadow on the sphere
Nope. Sadly, C3D doesn't support realistic shadows, only background shadows.Eduardo_B wrote:Okay, I've modified the default movie with the text rotating around the sphere (earth) and now see that it lacks the realistic final touch of a shadow on the sphere from the text. I've tried the shadow plug-in, but can't get the effect I want. Is this doable?
Eduardo_B
That seems so odd. In the manual it shows a shadow being projected onto the ground from text. Is the Y value how far the shadow is from the source of the shadow?dnavarrojr wrote:Nope. Sadly, C3D doesn't support realistic shadows, only background shadows.Eduardo_B wrote:Okay, I've modified the default movie with the text rotating around the sphere (earth) and now see that it lacks the realistic final touch of a shadow on the sphere from the text. I've tried the shadow plug-in, but can't get the effect I want. Is this doable?
Shadows are applied globally. Which means it applies to the whole project. Other cons is that they only take the shape of the facing camera. Yes, one can move the shadow using X and Y but it cannot be distorted or slanted. (Not true object-oriented shadowing). Also, the shadows are color-oriented and do not allow for transparency.
