Is it possible to add a filter to just a section of a clip? Whenever I drag a filter to a clip, it covers the entire clip. Additionally I'd like to adjust the aduio (mute, volume) for just a section of a clip instead of the entire clip. Is this possible? I am using version 7.
Thank you,
-Russ
Adding VIdeo FIlters to Part of a Clip
Unfortunately the filters are applied to the entire clip. However with some filters you can customize them by keyframe. This may allow you to have the filter applied only to a small portion of a clip. The only other way would be to cut the clip, and apply the filter to the cut portion.
To "mute' part of a clip, go to Audio View. You should see a "rubber band" running down the center of the audio clip. You can place nodes (key points) and drag them up or down to adjust the volume.
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
edit part of a lip
Never used V7 but can u not make new clips with a duration required + then add the filter/ mute audio then insert these into the timeline to replace the original clips after cutting out parts of the original clips that you want to alter? regards Ken
Ken Berry wrote:Unfortunately, the audio controls in VS7 are rather primitive, and I am afraid I have to say that Vidoman's advice only applies to later versions of VS. With VS7, it is all or nothing -- you can only change the volume for the whole clip.
