editing time of individual pictures (at once)
brucefl
motherboard: I7 3770
processor: 3-4 Gig
ram: 12gb
Video Card: NT Geoforce 640
Hard_Drive_Capacity: 2 T
Corel programs: VS21 VS18thru21 and more PIX13
Post by brucefl »
hi
Is there a way to select a bunch of pictures and edit the individual timing of them all at once. I started a project, and noticed when I inserted more pictures they were a second shorter than the first ones. I want to shorten the rest of them, only way I see to do this is one at a time. I can highlight them, but is there a way to change the timing for each one down a second?
thanks Bruce
Post by BrianCee »
click on the first one in the timeline - move to the last one and hold down 'Shift' as you click on it (standard Windows Multi-select operation) - they should all now highlight.
Top left corner of screen - click on 'Clip' and select the top option - "Change image/Color Duration" - in the dialogue box which opens set the duration to be applied to every image - note the options are 'Hours.minutes,seconds and frames' - click 'OK' - job should be done.
brucefl
processor: 3-4 Gig
ram: 12gb
only works with one clip
Post by brucefl »
It is grayed out, when I do that. Only seems to work with one clip at a time?
Post by Black Lab »
Nope, can't do it either. In fact, no matter what I do I can't get Clip > Change Image/Color Duration to be active.
brucefl
processor: 3-4 Gig
ram: 12gb
one at a time
Post by brucefl »
After you initially import still pictures, all you can do is one at a time. Would be a nice feature to add next time.
Post by BrianCee »
Are the pictures in the top video track or in the overlay track ??
Works fine for me when they are in the top track which is where I would normally put pictures - I agree it does not work if you have the pictures in an overlay track.
In that case is it not easier to delete them all - set a new default duration in 'Preferences' and then insert them all in the overlay track again.
