using picture as a background
Pink
Post by Pink »
hi, can anyone help me? i would like to use a picture as a background, with other pictures on top of it (like a scrapbook), how do i fade the picture in the background? do i place a mask over it and work with the opacity of the mask, say a white rectangle? how do i do this?
thanks!
bhawk
Re: using picture as a background
Post by bhawk »
Pink wrote:hi, can anyone help me? i would like to use a picture as a background, with other pictures on top of it (like a scrapbook), how do i fade the picture in the background? do i place a mask over it and work with the opacity of the mask, say a white rectangle? how do i do this?
thanks!
Once the picture is an object you can right click on the image, go into properties and adjust the transparancy using the slider
fortemac
Post by fortemac »
You can also go into the fill category of the easy pallette and find the fades. Once your upper layer is selected (the one you want to fade into the background), double-click a fade. The black sections totally erase the picture while the white portions show through. I like to right click the fades in the easy pallette and make my own too!
Cyndy
heinz-oz
Post by heinz-oz »
What exactly are you trying to do? If you put another image on top of your lower layers (objects) it will cover everything underneath.
Have a look at this image Image
I extracted objects from other images with masks and placed them on top of a background image.
fortemac
Post by fortemac »
Is this what you mean? This is how I use fades to make a scrapbook page featuring blended photos.
Cyndy
lakewud
Post by lakewud »
All pretty impressive but please someone tell me how i actually go about getting a photo of mine turned into an image to then manipulate at will and place onto another image aka montage sceniaro?
Been looking on here, having a play with PI, and going back to the manual, the section on masks..but just dont get it!!
All im wanting to do is....Have a background image, then place onto that 2 or three other photos, ideally faded/blended in i suppose to look a little better.
Please, start at the beginning.
lakewud
Post by lakewud »
Ok, so im managing to cut n paste one image onto another..and even twisting it!...but im wanting to fade/blur out the edges of the pasted pic...used the EDIT -Fade button..all that two-tone malarky...black on white? but all it does is fade out the entire pic..how do i just get the edges faded? or any other fancy effects to blurr them?
Using PI12.
heinz-oz
Post by heinz-oz »
I suggest the free beginners work shop to be found here http://www.pircnet.com/
You should apply a mask to the second image prior to placing it on your back ground image as an object. To try this, open your base image and your second image. Apply any of the frame masks from the EasyPalette to your second image, convert the selection to object and copy this selection to the clip board. Change to the base image and select "Paste >As New Object". Resize the image to suit, rotate it if needed and, voila... there you are :wink:
