Help please..urgent
davidberry1
Help please..urgent
Hi all,
please please please help me!!
i'm only a student at school and i have the task of creating a video promoting my school...
the project is to be given to the teacher on dvd and cd.What format should i save it as before i burn to disc and how do i convert the file.
please help its really urgent
thanks,
David
thanks,
David
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
Welcome David
Firstly what will the DVD be viewed using, a PC or a standalone DVD player (attached to a TV).
If the DVD will be viewed on a PC then what operating system does the PC use? Windows? Also is the file size important, does it need to be a small file size?
John a
It may also help us to help you a great deal David if you tell us where in this great wide world you are - that way we can be more specific about settings - please fill in the 'location' box in your profile so that it appears to the left like mine and jparnolds.
Sounds as though you have a great deal to learn in a very short time - please start by reading this article :-
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=13421
And as one Berry to another, I say, welcome to the forum!
But we also need to know how you are filming the original video, and what format it is in when you start off your project. Right click on some of the captured video within Video Studio and copy down ALL of its properties here please.
You also need to tell us what version of VS you are using, and as jp arnold has said, something about your computer specs and its operating system.
davidberry1
PAL (25 fps)
MPEG files
24 bits, 704 x 576, 25 fps
Upper Field First
(DVD-PAL), 4:3
Video data rate: Variable (Max. 5744 kbps)
Audio data rate: 192 kbps
yeh by the way i am only 16 and haven't had experience in video editing........ and at the end of my assignment sheet it says i have to burn the video to a dvd and cd.......
thanks for your time
MPEG files
Upper Field First
(DVD-PAL), 4:3
- ram: 2 GB
- sound_card: Intel GMA 950
In addition to the link already given above by Senior Forum Member BrianCee, please also view
Suggested Workflow
Suggested Workflow
- jparnold
- ram: 16GB DDR3
David,
We also need to know what format the output videos need to be in. Can we assume that as you need to hand in a CD and a DVD that the CD will be used with a PC (to view the video) and that the DVD will be used in a stand alone DVD player?
If this is the case then when you OUTPUT the video you will need to output it twice once in say MPEG2 or WMF format (the resulting file will then be burnt to a CD) and once direct to DVD.
It would seem that you are very new to video editing etc and there is a real learning path which can be learnt using Steve and Brian's suggested links which you should read carefully to ensure you do it correctly.
You could also use the DV TO DVD "wizard" which is displayed when Videostudio first starts up.
John a
davidberry1
