Adding Menus Question
astrovideo
Post by astrovideo »
I have 3 clips I am using to create a disk. How do I set it up so that the disk will return to the main menu between clips (after each clip is played) - insteading having the clips play one after the other?
Thak you,
-Russ
astrovideo
Re: Adding Menus Question
I'm sorry, I should have dug further before posting. I found the setting in Project Properties. Thank you.
astrovideo wrote:Hi,
Thak you,
-Russ
