VideoStudio Wish List for Future Versions
Re 5: I might be missing something here, as I don't have a Blu-Ray burner as yet. Do you mean that if you select Share > Create Disc > Blu-Ray, it won't accept AVCHD files for burning? Or if it does, it converts them to another of the Blu-Ray acceptable formats (HDV, WMVHD)? Or selecting Share > Create Disc > AVCHD won't work with a Blu-Ray disc in the burner?
FWIW, I currently burn a few AVCHD 'hybrid' discs i.e. burning the AVCHD in its native format on a standard DVD. As far as I can see, apart from it being on a standard DVD instead of a Blu-Ray disc, the structure burned to the disc is Blu-Ray compliant. It creates a BDMV folder with a number of sub-folders within that folder, including the Stream sub-folder which actually contains the AVCHD files. And they play fine in the Sony PS3 which is of course a Blu-Ray rated player. I would have thought it would do the same thing if you actually used a Blu-Ray disc instead of a standard DVD.
Re 6: I certainly agree. In fact, I cannot understand why this could not have happened right from the start. As you have probably also found, Make Movie Templates Manager cannot even create an AVCHD template which is another major oversight as far as I am concerned. And it's certainly one which I hope is covered in VS12.
As a footnote to the latter, since 95% of the video I am burning to my AVCHD hybrid discs is in fact HDV format, I do my editing as normal. But then, when editing is finished, I do not, as I normally do with other formats, convert it in the Editor to AVCHD using the silly VS11.5+ default (and only) AVCHD settings (Share > Create Video File > AVCHD).
Instead, I go straight to Share > Create Disc > AVCHD. This opens the burning module and automatically inserts my *project* file into the burning timeline as is. Then I click on the second icon in the bottom left of the burning screen and select 'Change MPEG settings'. I can then select AVCHD settings which suit me far more than the default VS ones. For instance, instead of using the VBR max 15000 kbps bitrate set by VS, which I find too low in final quality, I select CBR 16800 or 17000. (The former gives me leeway for a couple of extra minutes of video, given that using 17000 kbps will only give me around 20 minutes of AVCHD on a standard single layer DVD. Quite a number of my projects go just over that limit, no matter how much I edit and break up larger projects to fit within the hybrid disc limitations.)
Using that workflow, I can ignore the 'Do not convert compliant mpeg files' box (i.e. whether it is ticked or not) since what I have inserted in the burning timeline is still only in project HDV/mpeg-2 format, and thus not a compliant AVCHD/mpeg-4 file. But if you are using AVCHD files ab initio and actually insert real AVCHD in the burning timeline, you would probably need to un-tick the 'Do not convert' box. This would mean that your files are re-converted to the same properties during the burning process, and thus both significantly extend the time frame and also cause the usual loss of quality inherent in any recoding of the lossy mpeg format. But I am of the view that if you are only recoding once, and maintaining the original high quality settings, any loss of quality will be extremely minimal, and not detectable to the naked eye.
Using the default VS AVCHD settings, on the other hand, inevitably leads to significant and very detectable loss in quality! :cry:
Efenstor
Post by Efenstor »
Ken Berry wrote:Or if it does, it converts them to another of the Blu-Ray acceptable formats (HDV, WMVHD)?
Exactly. AVC support is compulsory for all blu-ray players and so there's no need to convert when the source is already AVC(HD).
P.S.: thanks for the template! :)
johnsweet
Wish 2 option in future versions
Post by johnsweet »
Hi every body,
First up all I ask apology for posting the same topic again.
I am one of the Big fan of video studio , I like this software than any other Video editing Software because it easy to handle and has lot of features. But there are 2 major things missing in this application.
Here I need to share with forum members with the help of images.
1. split while capturing in desired length
http://img2.freeimagehosting.net/image. ... 70162a.jpg
2. Selected clip should show tick marks in the library.
http://img2.freeimagehosting.net/image. ... e571e2.jpg
I wish It could be included in the Video studio version 12 or Pro version.
(If these links are not working you can copy paste it)
John
GRDVDjunkie
Features wish list for future versions of VideoStudio
Post by GRDVDjunkie »
1.Does anybody in Ulead/Corel ever studies other video editing programs manuals ? Take Premiere Elements 4 for example, which is a massive
296 DENSELY written .pdf and which explains every implication of doing and choosing this or that. Adobe does not assume that anybody has wo
rked with a video editor before in their life and they`ll try to explain AS MUCH AS possible to the user. By comparison, VS`s "manual" is just a
bloated "features and general capabilities" reference. Pity, because it
does undermine the program`s value.
2. Does anybody in Ulead/Corel ever cares to find out what gets insta-
lled on a user`s PC, when he buys other video editing programs, apart from the program code and various components ? With Premiere Ele
ments 4, you get a truck load of DVD (and Blu-ray) menus (over 2 GB in total) plus Movie Themes. With Pinnacle`s Studio Plus, you get a Bonus
(PAL in my case, since I am in Europe) DVD, packed with various goodies, readily available.
You lads at Corel, don`t have to just walk, you have to run in order to seriously compete with others. And yes, I TOTTALY AGREE THAT WE
DON`T need a new version of VS every single year ! Simply enhance its capabilities with patches, capture presets (to support new cameras) and above all, iron out the bloody bugs, if and when detected.
kinglerch
Change Speed in less than 1% increments
Post by kinglerch »
This has probably been brought up before, but it is astounding that you can change the speed of video and audio clips (a great feature) but only in 1% increments. It would be such a (seemingly) small change to allow 0.1% or 0.01% increments.
Why a 1% increment seems astounding is that sync is rarely off that much. A 1% change in a 3 minute clip changes the length by 2 seconds. A 60 minute video changes by 36 seconds. These are huge changes!
If you are trying to sync audio and video (which VideoStudio excels in) 1% increments are almost useless. Please enhance this feature :D
VideoStylist
Copying and Pasting into the TIMELINE Tracks
Post by VideoStylist »
I'm not sure if it has been brought up yet, but to be able to...
COPY & PASTE video clips/pics directly into the timeline tracks would be very convenient.
Right now we're copying and pasting to and from the library, then dragging it into the timeline/tracks, and then having to configure the clips the way we want it. Sure... we can copy the clip, then paste it into the library, but the next day we'll forget which clip is the right clip to drag into the timeline/tracks since the clips, having different set of functions, will all look the same in the library.
Thank you, Mr OoLed!
VideoStylist
Dennis Willis
Video Filter Preview Screend
Post by Dennis Willis »
A facility for increasing the size of the preview screens for those video filters requiring accurate placement or movement would be a great help.
Dennis
tvid101
Post by tvid101 »
Only been using VS 11.5+ a few days but would have liked:
1. Ability to save DVD creation settings when DVD creator window is closed.
2. Able to select scenes to cut in multi-trim instead of only scenes to keep.
3. User friendly custom menu creator.
4. User friendly conversion/rendering tool instead of just batch convert to lower quality.
Other than that, I'm enjoying the program.........it's pretty user friendly and works as advertised except for odd occasional crashes when handling large files.
Ducklet Cat
Post by Ducklet Cat »
1. Including FLV as a possibility when saving and sharing the work.
2. An easy way to add subtitles.
3. Supporting Arabic. I can't write Arabic in text. It comes out distorted.
metmot
motherboard: Asus M2N SLI
processor: AMD Athlon 64 x2 Dual Core 6000+ 3.0 gh
ram: 8 GB
Video Card: Nvidia Gforce 7300se
sound_card: Onboard PnP Sound Device
Hard_Drive_Capacity: 1.7 TB
Post by metmot »
I am too lazy to search and this may already be in this thread but I am amply annoyed today to write it again if so.
After you use VS for five or ten minutes you are very much aware from then and forever that transitions will be deleted if you move or delete a clip from the timeline.
LET ME TURN THAT DAMN NAG BOX OFF IN PREFERENCES!!!! Or even more novel approach how about a "don't show me this message again" check box right on the nag? I have enough mouse clicks to create a project without having that one forced on me constantly.
Ok I'm much better now
John
pakmenu
Post by pakmenu »
Where to start? have never been happy with ANY video editing program, mainly because I aim at video files that are kept on a Computer and played on a Computer screen, NOT on a interlaced device....
Deinterlacing to 50fps progressive material from my camcorder, into a state of the art videocodec (would be H264 now) is what i crave.
=> I had hoped to have more freedom exporting to a format of MY choice.
ie.: I want to have freedom to choose my fps, dimentions and audiocodec of the video. WHY am I still restricted o 720x576 25fps PAL INTERLACED?
EVEN when i choose the H264 format?
I want to export to ANY dmention, ANY fps, choose if interlaced or not, choose the videobitrate myself and have a Constant Quality option, choose the audio codec, and bitrate (inc VBR).
Right now the only good thing in the export function is "SAME AS FIRST VIDEO CLIP" BUT: the audio gets exported in 8 BIT PCM???
it's TERRIBLE! even with untrained ears it sounds terrible. why not 16 bit, so then i can recompress it to H264 and a audio codec of my choice later?
Please please give more choice in exporting formats, and... for the stupid people make a "SMART" export format that will choose the dimentions of the biggest dimention used in the clips and choose the frame rate of most clips used so that it's idiotproof.
even now i know few people who know the difference between PAL/NTSC interlaced/Progressive etc etc.
and what about the people that edit video shot with their digital camera??
a lot of these are actually clearer then video shot with interlaced (read half of the lines have gaps in them with every frame!!) DV cams.
but the nice crisp video of a digital camera will be terrible deteriorated when 640x480 is forced into 720x576 and the framerate altered!!!
sorry for going into a rant, it's been YEARS that i'm waiting for DECENT videosoftware and still there is none out there. I'm so dissapointed...
kinglerch
Post by kinglerch »
I could be mistaken, but I think these options are already available when exporting as an AVI. You can have any size, any bitrate, any fps, any compression, or no compression at all.
Isn't this flexible enough?
klingon_master
Post by klingon_master »
Are they ever thinking about adding more animations or objects into the latter versions. Cause I have Movie Edit Pro 11 and they had a few animations and objects you could add to your video. Now they have whole service you can download animations, titles, objects, and other things into your program. Cyberlink has an even better service for there powerdirector 7 that gives you access to free dvd menus, animations, objects, titles, etc. you can put into your videos. It's not a super important but you have the ability to add little things to your video that many others like even Vegas 9 don't offer.
VideoStudio 2 has been released and so this thread is now closed.
The new thread is here:
http://phpbb.ulead.com.tw/EN/viewtopic. ... 830#166830
Locked
