I'm using VS 9 and I gather from this forum that it will not run under Vista - does anyone have any thoughts about that?
Buying a New PC
Stratocastermagic
Buying a New PC
We are looking at buying a new PC for family use and I'm wondering what people would recommend as a decent spec for running VideoStudio.
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
Ensure the PC has at least 512MB of memory (ram) - more is even better.
Ensure that the hard drive is at least ATA100 with a speed of 7200rpm - I think that all current PCs would have this in fact use SATA drives. Video capture works better if you have TWO hard disks and that you capture to the hard disk which does not contain the operating system.
My PC is 4 years old with a Pentium 4 2.4Ghz processor which is quite good - current PC's will have faster processors. The speed of the processor mainly affects how fast you can render a video project. This usually doesn't worry me as I render overnight when I am asleep.
John a
Agree with everything in Johns reply in addition make sure you have a seperate 'Graphics Card' with it's own Memory 32Mb+ other wise the graphics will be useing your RAM.
Correct even VS10 had to be patched. Also bear in mind that it will be some time before 'Vista' will be completely compatible with the majority of Hard & Software available and be totally reliable. So you can either wait for the new VS11 expected daily or buy a cheap copy of XP off Ebay and run a dual boot system for a while.I'm using VS 9 and I gather from this forum that it will not run under Vista - does anyone have any thoughts about that?
Feedback after members have endeavoured to help you is not only good manners it also helps others to know if a given solution was effective. Thanks.
Stratocastermagic
Thanks for responses.
I've been looking at the thread on VS 11 (http://phpbb.ulead.com.tw/EN/viewtopic. ... 2a8ff950af), so maybe that's the way to go: upgrade to VS 11 (when it's available) and buy a Vista PC that meets its system requirements.
Actually running VISTA (if that's the OS) they recommend having about 2 gigs of memory for video editing. Probably to make use of the new Vista OS, it's code and new advanced graphics.
I would make the computer fairly powerful so it will last at least 6 months
going my the way computers progress. Or make sure you can upgrade it later.
