Cannot capture in mpeg2 format
Erik1967
Post by Erik1967 »
Hi.
I recently reinstalled Windows XP SP2 after a corruption of the registry.
I'm currently installing and testing all the applications and what struck me is that I don't seem to be able to capture in mpeg2 format anymore. This used to work! As far as I can remember, the mpeg2 format had to be selected from the dropdown menu of the capture tab.
Anyway, I can select MPEG but after a few seconds it goes back to DV. Same thing goes for the format DVD.
Can anyone explain this to me and how can I capture to mpeg2?
Are you capturing using Firewire? If so you should be able to capture to a variety of formats, including MPEG-2.
Have you went to Tools>Change Capture Plug-in, and change the Capture Plug-in to the MPEG capture plug-in?
Erik1967
Post by Erik1967 »
vidoman wrote:Are you capturing using Firewire? If so you should be able to capture to a variety of formats, including MPEG-2.
Thanks for the quick reply. Yes, I'm using Firewire. And if I go to "Change Capture Plugin" then I can see 4 possible selections:
Ulead DirectShow Capture Plugin
Ulead MPEG4 Capture Plugin
Ulead HDV Capture Plugin
Ulead DVB-T Capture Plugin
Directshow is currently selected. MPEG4 cannot be selected. HDV en DVB-T do not work at all.
Your install may be corrupt. You should show in the Capture Plug-in choices,
  • Ulead DirectShow Capture Plug-in
  • Ulead DSW MPEG Capture Plug-in
  • Windows Media Format Capture Plug-in
  • Ulead MPEG4 Capture Plug-in
  • HDV Capture Plug-in
  • DVB-T Capture Plug-in
So it seems that the MPEG Plug-in/ Codec may be missing from your system.
Erik1967
Post by Erik1967 »
I've uninstalled and re-installed ULead Videostudio several times, but unfortunately, it still doesn't work. Isn't there another way of installing these capture plug-ins?
Are you following the recommended uninstall/reinstall procedure as outlined
--> here <--
Erik1967
Post by Erik1967 »
sjj1805 wrote:Are you following the recommended uninstall/reinstall procedure as outlined
--> here <--
No I didn't, I simply used Add/Remove Programs of the control panel..
After reading your post I followed the recommended uninstall procedure... and yes, this solved the problem :D :D. I can now record in mpeg2 mode again. Thanks a lot sjj1805!
It surprises me a bit too. How is the average user supposed to know this procedure? Obviously the uninstall program isn't perfect and if you would not have given me this uninstall procedure, I would never have been able to reinstall VideoStudio properly. :o
roy wood
Post by roy wood »
Ah! that's what the Forums for Ulead gave us the Programme we get it to work.
whitejames
Post by whitejames »
Erik, are you recording HD at 1920x1080 resolution?
