Unable to empty recycle bin in VISTA..HELP!
kevinp
I am unable to delete or empty a videostudio file with vista in my recycle bin. It says it's a "Ulead PhotoImpact Image ". I have even tried to restore it, but it just sits in my bin....and when I try to delete it...it acts like it's trying to..but it never does...but it ANY help would be appreciated!!!!!!!!!!
SHADOW57
kevinp
SHADOW57
Probably in Windows Explorer like sjj1805 mentioned.
Maybe right click on the file in the Recycle Bin to see where
it's located.
I tried a test file, deleted it, and right clicked on it in
the Recycle Bin. It shows the location.
I use Dr Delete mostly for virus files but I was thinking
maybe it would help you too!
You can also post your problem in the computer forum at VideoHelp.com
There are a lot of helpful folks over there and questions are usually
answered quickly!
it's located.
answered quickly!
kevinp
First...roy wood...its avatar...not avater
Second...What "I" find distracting is that I am trying to find some advice for my problem and you felt you needed to reprimand Shadow57's avatar. I really don't care what his or anyone else's avatar looks like just so long as they are trying to help me. So unless you have a worth while suggestions for MY issue... post elsewhere.
Third....Thanks everyone else for the suggestions. I have tried them but still no luck. So if anyone else has a suggestions...let me know!
SHADOW57
kevinp.....
If the file was on a portable drive plug the drive back in and try to
delete the file.
Also, here is an article that might help.....
http://www.smartcomputing.com/editorial ... .asp&guid=
roy wood.....
Thank-you for the warm welcome.
delete the file.
roy wood.....
kevinp,
I don't know how Vista works, but in XP the system flushes the oldest items in the Recycle Bin when the bin gets full. (Look at the Bin properties to see how much space you have allocated to it.) Perhaps you could adjust the size of the bin and then create&delete some large dummy files so as to exceed the maximum bin size. The problem file might get flushed. It's worth a try.
rpwhitmore
I had a file that would not delete in Vista
I had a .MPG file made by VS10 in a folder and I went to that folder to delete it and my Explorer went to using 100% of my CPU in the task manager. I would click on the file to delete it and press delete and windows would come up with estimated time to delete and sit there thinking. It was a file with 0 bytes, made by VS10 after a program error of...can not open capture file or something close to that. Anyway, I went into safe mode and had no problem deleting then.
kevinp
Hey guys..thanks so much for the suggestions....but still no luck ;(
This is getting kind of crazy! Besides what's been mentioned above..I've also tried programs such as East-Tec to try to permanently delete any file that is in the bin....but that one ulead file remains.
This is a challenge for sure!!!
