The problem that I am running into is when I convert from another format such as DV at 720 X 480, the QT output is noticeably smaller. The vertical height appears to be about 5/6th the height of the original ( it leaves blank space at the top and bottom of the screen). The width appears to be about 7/8th of the original, again blank space on the left and right side of the screen. This does become noticeable when you go from a picture background that is full screen to the QT movie.
I have tried the nonsquare pixels option on compile and this helped a little. I am using Sorreson 3 (mispelled) compression at 74% if that makes any difference.
The actual playback quality is not bad, but I need a full screen.
I did not find anything about this on a quick screen of the postings, so if there is I am sorry.
