WS 2.0 with latest patch to 2.231 I think. Everything has been working just fine then started getting "data not burned to disc" errors and assumed it was my DVD burner. Also got "unspecified error error code 8004145d". So, installed new Sony burner DRU-710A. Same results .
I have two batchs of Verbatim 2X-R DVD's which have worked perfectly in the past. Now, neither one will work.
Also, Nero will not burn the .iso file.
I think it is not a hardware problem.
Nor, is it a media problem.
Nor , is it a WS problem in that Nero will not burn it either.
I do not have Roxio on this computer. Do not know what it is.
I am in a bind so any help would really be appreciated.
THanks
John
unspecified error 8004145d
htchien
Tried the General Updates in http://www.ulead.com/tech/dws/dws.htm ?
Properties of your source materials?
H.T.
H.T.
Ted (H.T.)
htchien
The properties of your source materials?? MPEG files? AVI files? or other file types?
H.T.
H.T.
Ted (H.T.)
masterpr
8004145d
Wth me it is a ready to go dvd folder. I have burned with this program dvd just fine. But now with 3 % I've got the error.
I had a version of Nero but i already uninstalled that and in the registry deleted as much as i could found of it.
all the patches i have downloaded and installed. I don't know what to do??
pauley
I'm not saying this is the answer, but it may be. I used to burn with a Pioneer A-03 which had 2 x max. I had a stock of 1 x and 2 x media. When I installed a 16 x DL burner, it simply refused the old discs and requires 4 x ±R minimum (it will accept 2 x -RW and 2.4 x +RW). I imagine that it cannot reduce the power of the laser sufficiently while burning.
Don
