I have heard that capturing in Microsoft AVI format is recommended over MPEG format because it does not compress the image. The thing is, when selecting AVI, on the Project Properties you can select a compression method (DV Video encoder type 1, DV Video encoder type 2, MJPEG compressor, etc.). So should I leave this blank (no compression)? Or is AVI with one of those methods still better than MPEG?
Now regarding resampling, in the preferences tab you can choose between Good, Better or Best. The manual says "choose best if you are preparing for final output". I thought resampling only happens when creating the final movie file, so what is the point of selecting Good or Better? When should they be used?
