I have had great success importing by chapters, DVDs created by my church to capture various events. However, when I take two successive chapters and lay them end to end on the timeline, at the very end of the first chapter, the audio drops out for a few frames. This also happens when I set the in / out markers of a section of video.
As an example, play a short piece of video in the viewer towards the end. At the point where the video ends, the marker continues to advance past that point a frame or two. No matter what I have tried, backing up the out marker, the effect is still the same, the audio cuts out a frame or two before the video actually is done.
This problem produces a dropped audio for a frame or two in the final rendering.
Is there some setting I have missed, or is this a problem with ???
Any advice will be greatly appreciated.
Kellie
Import DVD by Chapters - Audio Drop-out at out mark
Kellie_W
You may be better off importing the complete video from the dvd. This way the mpeg2 file will be continuous. Then edit accordingly.
When importing just check the top box in the import module. All the chapters will be highlighted. If you have the top box checked the whole mpeg2 file will be extracted to the harddisk.
