Which compression or setting should I save my edited video project, to obtain a high and high quality video?
Best High Quality Setting
Well I think you are getting the "just" of Devil's response..
If you have 1 hour of video, then you should be able to use a higher bitrate. The bitrates determine how much video/audio can fit on a disk, and that also determines the quality.
High-bitrates = less video per disk = better quality.
Low-bitrates = more video per disk = poorer quality.
Now with that if your source video is from say a VCR, then you can not get better quality then what you started with. A bitrate of 5000-6000 kbps will probably give you the best quality you could squeeze out of a VHS. If your source video is from a digital camcorder, or HD (Hi-Def), then of course you could use the higher bitrates (8000kbps +).
You can use a bitrate calculator to determine the best possible bitrates:
http://www.videohelp.com/calc.htm
