Just wondering if i can change the default prefix when capturing with VS10+, ie 'uvs070419-001'.
I just think it would make archiving much easier if i could set a prefix for each captured video, rather than doing it manually when there is 200+ clips.
Thankyou
Ryan
Quick Q - Can i change the default capture file name?
- ram: 2 GB
- sound_card: Intel GMA 950
No.
You may be interested in a free utility though
The Rename
THE Rename is a program designed to help you to rename files and folders en masse with a number of possibilities and options.
This is a freeware program. You can use it in any situation (professional and personal use)
http://www.herve-thouzard.com/modules/w ... rticleid=1
Lupas Rename
Lupas Rename is a FREEWARE program developed to rename a few or a massive number of files with a lot of features
It works on Win95, Win98, WinME, WinNT, Win2K and WinXP.
It is a simple .EXE file and doesn't need any other external libraries.
http://www.azheavymetal.com/~lupasrename/news.php
The Rename
Lupas Rename
This is, for me at least, the most stupid weakness in VS, and I have tended to rant about it since I started using VS with version 7 about 5 years ago. One would think it would be absolutely easy to allow users to set their own names for files. Lots of other editing programs do it. But not Ulead....
5LEEPER
Thank you, this was very helpful.sjj1805 wrote:No.
The Rename
Lupas Rename
Ryan
Re: Quick Q - Can i change the default capture file name?
Hi5LEEPER wrote:Just wondering if i can change the default prefix when capturing with VS10+, ie 'uvs070419-001'.
Thankyou
Ryan
You could of course create a separate capture folder for each capture, giving each a unique name.
This would identify the folder content.
Yep the captured files would still have the date format.
It is worth having a separate capture/working folder for your projects.
