How to? Text with light rays shining through or from
wontonpe
I am looking into how to make text titles with a "light shining through" effect. Where the light comes from "inside" the text and shines out from it. I would like to make the light cycle from left to right as if a light is moving behind the text.
- ram: 2 GB
- sound_card: Intel GMA 950
Just throwing in an idea rather than the solution as I haven't time to set something up.
I think it is possible by using masks and layers.
In a background track you need to have the light effect moving as you mention.
Then you need a mask containing your text so that the text is allowing the light through.
A bit like this post....
Creating Filled Text from a Photo
(I was going to post a screen shot but the pictures appear to be temporarily unavailable - I have sent a message to the author of that post to see if they can be restored)
Other useful links that may help constructing this
Creating an animated background
VS 8: Light Emitting Scrolling Credits
wontonpe
Getting Closer
Well, I did manage to do something close to what I want. (like the titles in The Mask of Zorro) I did use a text mask & background image, as you suggest, but I need to tweek it quite a bit to get the look I am wanting. I will post my final result and describe how I figured it out. (If I do)
I have found plug-in's that do it perfectly - but I don't have After Effects or any of that other high dollar stuff to plug it into. The only one I could afford was not compatible with Ulead.
harry_hariz
after effect
hmmm,did uvs n mp support for adobe after effects?i want to add more transition la..
