Couple odd things happening I could use some help with...
Hal05154
Post by Hal05154 »
If you could help me out....
I've been using DVD MF 5. Added a new DVD burner and installed on my Win2000 machine. Now here are the odd things that are happenig.
DVD MF runs slow as molasses.
I tried converting an avi file to a wmv using Window MovieMaker on my laptop and copied the file to my Win2000 machine. The file plays fine, but when I burned it the way an audio synch problem after about 5 minutes of play time.
Thanks!
GeorgeW
Re: Couple odd things happening I could use some help with..
Post by GeorgeW »
Hal05154 wrote:If you could help me out....
Thanks!
Are you converting to wmv, and then re-converting to dvd compliant mpeg :?: That's alot of conversions (and sometimes problematic). What format is the original video -- try to encode for DVD only once...
btw, what are the specs of your Win2K Machine :?:
George
Hal05154
Post by Hal05154 »
The reason I converted to wmv was DVDMF would NOT accept the original AVI file.
My Win2K is an older 600mhz machine.
Thanks!
GeorgeW
Post by GeorgeW »
Hal05154 wrote:The reason I converted to wmv was DVDMF would NOT accept the original AVI file.
Thanks!
What processor is that (Pentium III :?: ). How much memory does it have :?:
It's going to be a challenge to run MF5 on a P-III 600 (if that's what it is). And if you do run it successfully, it's going to take a long time to encode...
What format is the original video :?:
I forget what the system requirements are for MF5 -- anyone else happen to have the min system requirements for MF5 :?:
George
Minimum system requirements for MovieFactory 5 / 5+
* Intel® Pentium® 4 1.8 GHz, AMD Athlon™ 64 2800+ (Intel® Pentium® 4 Dual Core 3.0 Ghz, AMD Athlon™ 64 X2 Dual-Core 3800+ or above recommended for HD project)
* 256 MB RAM (1 GB or above recommended for HD project)
* Microsoft® Windows® 2000 SP4, XP SP2, MCE, XP 64 bit
* 40 GB hard disk free space for program installation (80 GB or above recommended for HD project)
* DirectX® 9.0, Windows Media Format 9, Macromedia Flash Player 7, Microsoft Internet Explorer 6 or above
* Windows® compatible sound card
* Windows® compatible display with 1024 x 768 resolution or above
* Windows® compatible AGP or PCI graphic card (overlay support is recommended)
* Windows® compatible mouse or pointing device
Optional Requirements
* Intel® Pentium 4, Dual Core 3.0 GHz, AMD Athlon™ 64 X2 Dual-Core 3800+ or higher is required when capturing and burning from HDV/TV Tuner to an HD project or when capturing BD straight to disc.
* USB1.0/2.0 or PCI capture devices compliant with WDM standards and PC cameras
* IEEE-1394 (FireWire) I/O devices compliant with OHCI standards cards for use with DV/HDV/D8 camcorders
* PCI, TV tuner, USB capture device for analog capture (WDM support)
* Windows® compatible BD-RE, DVD-R/RW, DVD+R/RW, DVD-RAM, CD-R/RW drives
* 5 GB of available hard drive space or higher for 2 hours of high-quality DVD video capturing
* 5 GB of available hard drive space or higher for DVD disc burning
* 50 GB of available hard drive space or higher for 3 hours of HD-quality video capturing
* 50 GB of available hard drive space or higher for BD disc burning
