mOVIE fATORY 6 PLUS WILL NOT RELOAD ITS OWN PROJECTS
delonti
I can create a dvd menu and submenus with videe and name and save it but when I try to reload it it stops at 5% and then locks up the computer. I can load projects I made with an earlier version of movie factory but if I make changes with 6 plus the same thing happens when I try to reload it.Any help because I sent this to Ulead support and got no help.
user33
DVD Movie Factory 6 + Failure
My Movie Factory 6 Plus does not reload own project either. It freezes at 5% until terminated externally. Even absolutely empty projects (just for test) does not reload. Also it MF 6 Plus hangs and then vanishes when "Add Video File" or "Create a Slideshow" button is pressed. I try their techsupport exactly a month ago, still without result.
user33,
You either have a corrupt MF6 installation or something on the computer such as a video/audio codec package is conflicting with MF6+.
Does your ATI Capture Card work properly for capturing using the ATI Video Recorder? Are you using the original ATI video catalyst drivers or the latest updated drivers.
htchien
If it hangs after you clicks on "Add Video Files" or "Create Slideshow", it's usually a conflict issue with the codec packs installed in your system.
Use AVICodec to know how many codec packs are installed in your system, and see if there is any possible conflicts between those codec packs and DVDMF 6.
http://avicodec.duby.info/
Hope this helps.
Hope this helps.
Ted (H.T.)
